Board Feet Chart and Calculator
One board foot of lumber is one square foot that is one inch thick. Board foot is a volume measurement used for lumber, where
- 1 board foot = 144 in3 = 1⁄12 ft3 = 2360 cm3 = 2.360 liters = 0.002360 m3
Board feet can be calculated as
BF = t wft L
= t win L / 12 (1)
BF = board feet
wft = nominal lumber width (ft)
win = nominal lumber width (in)
t = nominal lumber thickness (in)
L = nominal lumber length (ft)
Note the use of inches vs. feet.
Board Feet Calculator
Default values for a piece of lumber with dimensions 2" x 4" x 6'.
- Download Board Feet Chart as pdf-file
Example - Beard Feet
The board feet for lumber 3 inches thick, 2 inches wide and 12 ft long - can be calculated as
BF = (3 in) (2 in) (12 ft) / 12
= 6 board feet
- as indicated in the table above.
Quick Approximation for Calculating Board Feet
- 1 x 4 - divide linear length (feet) by 3 - (length x 1/3)
- 1 x 6 - divide linear length (feet) by 2 - (length x 1/2)
- 1 x 8 - multiply linear length (feet) by 0.66 - (length x 2/3)
- 1 x 12 - linear length (feet) equals board feet - (length x 1)
- 2 x 4 - multiply linear length by 0.66 - (length x 2/3)
- 2 x 6 - linear length (feet) equals board feet - (length x 1)
- 2 x 8 - multiply linear length by 1.33 - (length x 1 1/3)
- 2 x 12 - multiply linear length by 2 - (length x 2)
Density of Wood Species: Data & Material Guide
Electrical Parallel Circuits
Glue-Laminated Timber - Dimensions
Common sizing of glue-laminated timber.
Hardwood and Softwood Species
Species of hardwood vs. softwood.
Hardwood Lumber - Dimensions
Sizing of hardwood lumber.
Lumber - Surface Finishing
Lumber and surface finishing abbreviations.
Lumber Weights: Green, Kiln-Dried & Pressure-Treated Wood
Maximum Floor Joist Span
No. 1 and No. 2 Grade of Douglas fir and maximum span floor joists - imperial units
Softwood and Hardwood - Structural Strength Classes
Strength classes, bending stress and mean density of hardwood and softwood
Softwood Lumber - Dimensions
Commercial softwood lumber dimension chart - nominal and actual sizes.
Softwood Lumber - Grading
Rough lumber, surfaced lumber (dressed), worked lumber, shop and factory lumber and yard lumber.
Softwood Lumber - Standard Sizes
Nominal and minimum-dressed lumber sizes.
Structural Lumber - Section Sizes
Basic size, area, moments of inertia and section modulus for timber - metric units.
Wood Headers - Max. Supported Weight
