Lumber - Surface Finishing
| Abbreviation Examples | Surface Finishing |
| S1S | Smooth surface, one side |
| S1S1E | Smooth surface, one side, one end |
| S1S2E | Smooth surface, one side, two ends |
| S2S | Smooth surface, two sides |
| S2S1E | Smooth surface, two sides, one end |
| S2S2E | Smooth surface, two sides, two ends |
| S3S | Smooth surface, three sides |
| S3S1E | Smooth surface, three sides, one end |
| S3S2E | Smooth surface, three sides, two ends |
| S4S | Smooth surface, four sides |
| S4S1E | Smooth surface, four sides, one end |
| S4S2E | Smooth surface, four sides, two ends |
| R/E | Resawn (same as S1S or S1S2E) |
| R/O or R/S | Rough sawn (no smooth surfaces) |
| CM | Center matched |
| D & M | Dressed and matched |
| T & G | Tongue and grooved |
| EV1S | Edge vee on one side |
| S1E | Surfaced one edge |
Board Feet Chart and Calculator
Board feet is used as a volume measurement of lumber.
Density of Wood Species: Data & Material Guide
Glue-Laminated Timber - Dimensions
Common sizing of glue-laminated timber.
Hardwood and Softwood Species
Species of hardwood vs. softwood.
Hardwood and Softwoods - Recommended Drill Bit Speeds
Hardwood and softwood drill speed chart.
Hardwood Lumber - Dimensions
Sizing of hardwood lumber.
Sandpapers - Grit Sizes
Grit sizes ranging 12 - 600.
Softwood and Hardwood - Structural Strength Classes
Strength classes, bending stress and mean density of hardwood and softwood
Softwood Lumber - Dimensions
Commercial softwood lumber dimension chart - nominal and actual sizes.
Softwood Lumber - Grading
Rough lumber, surfaced lumber (dressed), worked lumber, shop and factory lumber and yard lumber.
Softwood Lumber - Standard Sizes
Nominal and minimum-dressed lumber sizes.
Unified Thread Standards: UNC & UNF Size Charts & Specifications
US Wood Screws - Pilot Holes
Hard wood and soft wood pilot holes, shank clearance holes and countersink diameters.
