Hardwood and Softwoods - Recommended Drill Bit Speeds
Recommended drill bit speed in hardwood and softwood are indicated below:
Diameter (in) | Speed (rpm) | |||||
Softwood (Pine) | Hardwood (Hard Marple) | Acrylic | Brass | Aluminum | Steel | |
Twist drill bits | ||||||
1/16 - 3/16 | 3000 | 3000 | 2500 | 3000 | 3000 | 3000 |
1/4 - 3/8 | 3000 | 1500 | 2000 | 1200 | 2500 | 1000 |
7/16 - 5/8 | 1500 | 750 | 1500 | 750 | 1500 | 600 |
1 1/16 - 1 | 750 | 500 | - | 400 | 1000 | 350 |
Brad-point bits | ||||||
1/8 | 1800 | 1200 | 1500 | - | - | - |
1/4 | 1800 | 1000 | 1500 | - | - | - |
3/8 | 1800 | 750 | 1500 | - | - | - |
1/2 | 1800 | 750 | 1000 | - | - | - |
5/8 | 1800 | 500 | 750 | - | - | - |
3/4 | 1400 | 250 | 750 | - | - | - |
7/8 | 1200 | 250 | 500 | - | - | - |
1 | 1000 | 250 | 250 | - | - | - |
Forstner bits | ||||||
1/4 - 3/8 | 2400 | 700 | - | - | - | - |
1/2 - 5/8 | 2400 | 500 | 250 | - | - | - |
3/4 - 1 | 1500 | 500 | 250 | - | - | - |
1 1/8 - 1 1/4 | 1000 | 250 | 250 | - | - | - |
1 3/8 - 2 | 500 | 250 | - | - | - | - |
Spade bits | ||||||
1/4 - 1/2 | 2000 | 1500 | - | - | - | - |
5/8 - 1 | 1750 | 1500 | - | - | - | - |
1 1/8 - 1 1/2 | 1500 | 1000 | - | - | - | - |
1 5/8 - 2 | 1200 | 700 | - | - | - | - |
Density of Wood Species: Data & Material Guide
Drill Bits - Conversion Chart
Convert between drill bit dimensions - gauge numbers, inches and mm.
Hardwood and Softwood Species
Species of hardwood vs. softwood.
Lumber - Surface Finishing
Lumber and surface finishing abbreviations.
Metric Bolt Heads and Wrench Sizes
ANSI/SO, DIN and JIS bolts.
Steel Bolts - SAE Grades
US Wood Screws - Nominal Sizes
Wood screws - nominal sizes vs. diameters.
US Wood Screws - Pilot Holes
Hard wood and soft wood pilot holes, shank clearance holes and countersink diameters.
Withworth Threads - Taps and Drill Sizes
Taps and drill sizes used for Whitworth - ISO 7 and ISO 228 threads.
Wood Hardness
Soft and hardwood - the Janka Hardness scale.
Wood Screws - Withdrawal Force
Allowable withdrawal load force.
