no.
Convert between drill bit dimensions - gauge numbers, inches and mm.
Hardwood and softwood drill speed chart.
Sizing of hardwood lumber.
Lumber and surface finishing abbreviations.
Recommended clearance holes and drill tap sizes.
Allowable withdrawal load for nail and spikes.
Grit sizes ranging 12 - 600.
Metric versus Imperial equivalent screw dimensions.
Machine screw diameters.
Wood screws - nominal sizes vs. diameters.
Allowable withdrawal load force.
