Softwood and Hardwood - Structural Strength Classes
Structural timer is classified according the EU-code in different strength grades - where
- D-Classes - refer to Deciduous Tree Species
- C-Classes - refer to Coniferous Tree Species
Strength classes and structural softwoods and hardwoods physical properties:
Strength Class | Characteristic Minimum Bending Strength - σ - (MPa) | Typical Density - ρ - (kg/m3) |
C14 | 14 | 350 |
C16 | 16 | 370 |
C18 | 18 | 380 |
C20 | 20 | 390 |
C22 | 22 | 410 |
C24 | 24 | 420 |
C27 | 27 | 450 |
C30 | 30 | 460 |
C35 | 35 | 480 |
C40 | 40 | 500 |
C45 | 45 | 520 |
C50 | 50 | 550 |
D30 | 30 | 640 |
D35 | 35 | 670 |
D40 | 40 | 700 |
D50 | 50 | 780 |
D60 | 60 | 840 |
D70 | 70 | 1080 |
- 1 MPa = 106 Pa
- BS EN 338
Use the Engineering ToolBox - SketchUp Extension - to add Construction Lumber to Your Models
• Beams and Columns
Board Feet Chart and Calculator
Board feet is used as a volume measurement of lumber.
Compression and Tension Strength of some common Materials
Common materials and average ultimate compression and tension strength.
Density of Wood Species: Data & Material Guide
Drill Bits - Conversion Chart
Convert between drill bit dimensions - gauge numbers, inches and mm.
Hardwood and Softwood Species
Species of hardwood vs. softwood.
Lumber - Surface Finishing
Lumber and surface finishing abbreviations.
Modulus of Rigidity
Softwood Lumber - Grading
Rough lumber, surfaced lumber (dressed), worked lumber, shop and factory lumber and yard lumber.
Structural Lumber - Section Sizes
Basic size, area, moments of inertia and section modulus for timber - metric units.
Structural Lumber - Properties
Trusses
Common types of trusses.
Wood - Compressive Strength vs. Moisture Content
Red Spruce, Longleaf Pine and Douglas Fir - moisture content and their compressive strength.
Wood - Density vs. Moisture Content
The density of wood versus moisture content.
Wood Beams - Strength of Material
Wood Columns - Safe Loads
Safe loads for wood columns.
Wood Hardness
Soft and hardwood - the Janka Hardness scale.
Wood Headers - Max. Supported Weight
Wood Screws - Withdrawal Force
Allowable withdrawal load force.
Wood, Panel and Structural Timber Products - Mechanical Properties
Density, fibre stress, compressive strength and modulus of elasticity of clear wood, panel and structural timber products.
