Wood - Compressive Strength vs. Moisture Content
Moisture content influence compressive (parallel to grain) strength of Red Spruce, Longleaf Pine and Douglas Fir:
Indicated strengths are relative to wood containing 2% moisture.
- Red Spruce - air dried : 14% moisture content, kiln dried : 6% moisture content
- Longleaf Pine - green wood : 20 % moisture content
- Douglas Fir - green wood : 24 % moisture content
Example - Compressive Strength of Moist Spruce
The compressive strenght of spruce is normally in the range 18 - 39 MPa (2610 - 5655 psi). The diagram above indicatees that maximum strengt is reduced to 50% for spruce with 16% moisture. The reduced range can be calculated as
(18 - 39 MPa (2610 - 5655 psi)) * 0.5
= 9 - 19.5 MPa (1305 - 2828 psi)
Density of Wood Species: Data & Material Guide
Fire Wood - the Cord
The cord unit for purchasing fuel wood.
Hardwood and Softwood Species
Species of hardwood vs. softwood.
Lumber Weights: Green, Kiln-Dried & Pressure-Treated Wood
Machine Stress Rated (MSR) and Machine Evaluated (MEL) Lumber
Grading of lumber in North America
Moisture Content Calculation
Calculate the moisture content in products like wood on wet and dry basis.
Softwood and Hardwood - Structural Strength Classes
Strength classes, bending stress and mean density of hardwood and softwood
Structural Lumber - Properties
Wood - Combustion Heat Values
Combustion of wood and firewood heat values for species like Pine, Elm, Hickory and more.
Wood - Density vs. Moisture Content
The density of wood versus moisture content.
Wood and Bio Mass - Combustion Heat
Combustion heat values for wet and dry wood - Btu/pounds, kJ/kg and kcal/kg.
Wood Beams - Strength of Material
Wood Columns - Safe Loads
Safe loads for wood columns.
Wood Hardness
Soft and hardwood - the Janka Hardness scale.
Wood Headers - Max. Supported Weight
Wood, Panel and Structural Timber Products - Mechanical Properties
Density, fibre stress, compressive strength and modulus of elasticity of clear wood, panel and structural timber products.
