Moisture Content Calculation
Moisture content is the amount of water present in a moist sample of a product like wood, soil or similar. Moisture content  can be be expressed on wet or dry basis.
Moisture Content on Dry Basis
Moisture content on dry basis is the mass of water to the mass of dry solid:
MCd = mh2o / md                                        (1)
MCd = moisture content on dry basis
mh2o = mass of water (kg, lb)
md = mass of dry solid (kg, lb)
Moisture content on dry basis is commonly used in the timber industry. Note that it is common to multiply values with 100%.
Water Content on Wet Basis
Water content on wet basis is the mass of water to the mass of water and mass of solid:
MCw = mh2o / m
    =  mh2o / mh2o + md                                   (2)
MCw = moisture content on wet basis
mw = total mass of moist - or wet - sample - mass of solid and mass of water (kg,lb)
Dry vs. Wet Moisture Calculator
Example - Water Content in Birch on Wet Basis
The density of air-dried seasoned dry Birch is 705 kg/m3 with 20% (0.2) water content. The amount of water per unit volume can be calculated by transforming (2) to
mh2o = mw MCw
       = (705 kg/m3) (0.2)
       = 141 kg/m3
The amount of solids can be calculated as
md = (705 kg/m3) (1 - 0.2)
     = 564 kg/m3
Example - Moisture Content in Birch on Dry Basis
The density of air-dried seasoned dry Birch is 705 kg/m3 with 20% (0.2) moisture content. Equation (1) can be modified to
MCd = mh2o / (m - mh2o)                                  (1b)
m = mass  water and solid (kg, lb)
This equation can be transformed to
 mh2o = MCd m / (1 + MCd)                  (1c)
The moisture content per unit volume can be calculated as
mh2o = (0.2) (705 kg/m3) / (1 + (0.2))
       = 117.5 kg/m3
md = m - mh2o
     = (705 kg/m3) - (117.5 kg/m3)
     = 587.5 kg/m3
Moisture and Water Content Calculator
Material Properties
Air - Drying Force
The drying force of air depends on the air moisture holding capacity and the water surface to air evaporation capacity.
Air - Humidity Ratio
Compressed Air - Water Content
Saturation pressure and maximum water content in compressed air.
Fruits and Vegetables - Optimal Storage Conditions
Optimal temperature and humidity conditions for common fruits and vegetables.
Soil - Water Content
Water or moisture content in soil.
Water Content in Food and other Products
Water content before and after drying - in food and other products cork, grain, soap, peat, wood and more.
Wood - Compressive Strength vs. Moisture Content
Red Spruce, Longleaf Pine and Douglas Fir - moisture content and their compressive strength.
