Before Drying
The SI-system, unit converters, physical constants, drawing scales and more.
The drying force of air depends on the air moisture holding capacity and the water surface to air evaporation capacity.
Drying temperature and time for products like food, coffee, fruits, lumber and more.
Energy in carbohydrates, fats and proteins.
pH in common food products - like apples, butter, wines and more.
Specific heat of common food and foodstuff like apples, bass, beef, pork and many more.
Bulk densities of some common food products like grain, corn, barley, sugar and more.
Osmotic pressure in food products.
Absolute (dynamic) viscosity for common food products.
Common bacteria and viruses found in food.
Thermal conductivity of selected foodstuff like apples, beef, sugar and more.
Thermal diffusivity of some selected food products.
Practical storage life for common frozen food products.
Optimal temperature and humidity conditions for common fruits and vegetables.
Heating with microwaves.
Calculate the moisture content in products like wood on wet and dry basis.
Pasteurization methods, time and temperatures.
Water content before and after drying - in food and other products cork, grain, soap, peat, wood and more.
