Drying Temperatures and Times for Various Products
Drying Temperature and Time for Products
MaterialDrying Temperature
(oC)
Drying Time
(hr)
Bedding 66 - 88
Cereals 43 - 66
Coconut 63 - 68 4 - 6
Coffee 71 - 82 24
Cores, oil sand 150 0.5
Films, photo 32
Fish feed 70 - 110 0.5 - 1.5
Fruits, vegetable 60 2 - 6
Furs 43
Glue 21 - 32 2 - 4
Glue size on furniture 54 4
Gut 66
Gypsum wall board, start wet 175
Gypsum wall board, finish 88
Gypsum blocks 175 - 88 8 - 16
Hair goods 66 - 88
Hats, felt 60 - 82
Hops 49 - 82
Hides, thin 32 2 - 4
Ink, printing 21 - 150
Knitted fabrics 60 - 82
Leather, thick sole 32 4 - 6
Lumber, green hardwood 38 - 82 3 - 180
Lumber, green softwood 71 - 105 24 - 350
Macaroni 32 - 43
Matches 60 - 82
Milk 120 - 150
Paper glued 54 - 150
Paper treated 60 - 93
Rubber 27 - 32 6 - 12
Soap 52 12
Sugar 66 - 93 0.3 - 0.5
Tannin 120 - 150
Terracotta 66 - 93 12 - 96
Material Properties
Air - Drying Force
The drying force of air depends on the air moisture holding capacity and the water surface to air evaporation capacity.
Food Products - Osmotic Pressures
Osmotic pressure in food products.
Food-borne Infections and Diseases
Common bacteria and viruses found in food.
Foods - Thermal Conductivities
Thermal conductivity of selected foodstuff like apples, beef, sugar and more.
Foodstuff - Thermal Diffusivity
Thermal diffusivity of some selected food products.
Removing Heat with Air
Calculating heat removed with air by measuring the wet bulb temperature.
Water Content in Food and other Products
Water content before and after drying - in food and other products cork, grain, soap, peat, wood and more.
