Removing Heat with Air
The wet bulb temperature is a measure of the total heat in moist air - the mixture of dry air and vapor.
If the initial and final wet bulb temperatures in a heating or cooling processes are known - the heat transported by the air in the processes can be calculated by using the charts below.
Heat Transported by Air - kJ per kg
Example - Heat Removed by Moist Air
Air with initial wet bulb temperature 30oC (green line) is cooled down to a final temperature 10oC. From the diagram above we can estimate that
aprox. 70 kJ
of heat is removed.
Heat Transported by Air - kJ per m3
Heat Transported by Air - Btu per lb
Heat Transported by Air - Btu per Cu. Ft.
Air Psychrometrics
Air - Drying Force
The drying force of air depends on the air moisture holding capacity and the water surface to air evaporation capacity.
Air Heating Systems
Air heating buildings - heat supply vs. air flow and temperature.
Cooling and Heating Equations
Dry Air Thermodynamic and Physical Properties – Density, Specific Heat, Viscosity
THe essential thermodynamic properties of dry air like specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K.
Drying Temperatures and Times for Various Products
Drying temperature and time for products like food, coffee, fruits, lumber and more.
Humid Air - Heating
Latent Heat Flow
Liquids - Vapor Pressures
Vapor and saturation pressure for some common liquids.
Moist Air - Enthalpy
Moist Air - Relative Humidity
Relative humidity in moist air is the ratio of partial vapor pressure to air pressure.
Moist Air - Vapor Pressure
Vapor pressures vs. dry and wet bulb temperatures in moist air.
Moist Air - Water Vapor and Saturation Pressure
Saturation pressure of water vapor in moist air vs. temperature.
Specific Heat Capacity of Air: Isobaric and Isochoric Heat Capacities at Various Temperatures and Pressures
Online calculator with figures and tables showing specific heat (Cp and Cv) of dry air vs. temperature and pressure. SI and imperial units.
Water Vapor Saturation Pressure: Data, Tables & Calculator
