The density of water vapor can be expressed as:
ρ w = 0.0022 p w / T (2)
p w = partial pressure water vapor (Pa, N/m 2 )
ρ w = density water vapor (kg/m 3 )
T = absolute dry bulb temperature (K)
Saturation pressure and density of water vapor for common temperatures
Temperature | Saturation Pressure | Density | |||||
( o C) | ( o F) | (Pa) | (mmHg) | (psia) | (inHg) | (kg/m 3 ) | 10 -3 (lb/ft 3 ) |
0 | 32 | 603 | 4.6 | 0.09 | 0.18 | 0.005 | 0.30 |
10 | 50 | 1212 | 9.2 | 0.18 | 0.36 | 0.009 | 0.59 |
20 | 68 | 2310 | 17.4 | 0.33 | 0.68 | 0.017 | 1.08 |
30 | 86 | 4195 | 31.7 | 0.61 | 1.24 | 0.030 | 1.90 |
40 | 104 | 7297 | 55.1 | 1.06 | 2.15 | 0.051 | 3.20 |
50 | 122 | 12210 | 92.2 | 1.8 | 3.60 | 0.083 | 5.19 |
60 | 140 | 19724 | 149 | 2.9 | 5.82 | 0.13 | 8.13 |
70 | 158 | 30866 | 233 | 4.5 | 9.11 | 0.20 | 12.3 |
80 | 176 | 46925 | 354 | 6.8 | 13.8 | 0.29 | 18.2 |
90 | 194 | 69485 | 525 | 10.1 | 20.5 | 0.42 | 26.3 |
100 | 212 | 100446 | 758 | 14.6 | 29.6 | 0.59 | 36.9 |
120 | 248 | 196849 | 1486 | 28.6 | 58.1 | 1.10 | 68.7 |
140 | 284 | 358137 | 2704 | 51.9 | 105.7 | 1.91 | 119 |
160 | 320 | 611728 | 4619 | 88.7 | 180.5 | 3.11 | 194 |
180 | 356 | 990022 | 7475 | 144 | 292.1 | 4.80 | 300 |
200 | 392 | 1529627 | 11549 | 222 | 451.2 | 7.11 | 444 |
The Saturation pressure of water vapor in moist air at dry bulb temperature 25 o C can be calculated:
First, convertion from °C to K:
( 25 °C) + 273 = 298 (K)
Then Eq. (1) is used:
p ws = e (77.3450 + 0.0057 (298 K) - 7235 / (298 K) ) / 298 [K] 8.2
= 3130 (Pa)
The drying force of air depends on the air moisture holding capacity and the water surface to air evaporation capacity.
Thermodynamic properties of dry air - specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K.
Pressure, temperature and volume in a perfect ideal gas like moist air (air with water vapor).
Vapor and saturation pressure for some common liquids.
The pressure in a mixture of dry air and water vapor - humid or moist air - can be estimated by using Daltons Law of partial pressures.
Humidity ratio of moist air to humidity ratio of saturated moist air.
Density of moist air vs. pressure ranging 75 - 1000 mmHg.
Mole fraction of water vapor is the ratio of water molecules to air and water molecules.
Dry and wet bulb temperatures, saturation pressure, water vapor weight, specific volume, heat and more.
Vapor pressures vs. dry and wet bulb temperatures in moist air.
Calculating heat removed with air by measuring the wet bulb temperature.
Vapor pressure and specific weight of water at temperatures ranging 32 to 212 oF - Imperial Units.
The Wet Bulb Globe Temperature can be used to measure the general Heat-Stress index.
