Wet Bulb Globe Temperature (WBGT)
The Wet Bulb Globe Temperature (WBGT) can be measured by
  • the black globe temperature
  • the natural wet-bulb temperature
  • the shade air temperature
Outdoor with Solar Radiation
The Wet Bulb Globe Temperature (WBGT) for outdoor conditions:
WBGT = 0.7 Tnwb + 0.2 Tg + 0.1 Ta                                (1)
WBGT = the Wet Bulb Globe Temperature (oC)
Tnwb =  the natural wet-bulb temperature (oC)
Tg = the black globe temperature (oC)
Ta = the (shade) air temperature (oC)
The black globe thermometer (Tg)
A 150 mm (6 inch) black globe with a thermometer located at the centre.
Represents the integrated effects of radiation and wind.
The natural wet-bulb temperature (Tnwb)
A thermometer with its bulb covered with a wettened cotton wick supplied with water. Evaporation cools the thermometer. Not shielded from wind or radiation.
Represents the integrated effect of humidity, wind and radiation.
The (shade) air temperature (Ta)
Measured by a thermometer shielded from radiation.
Indoor - with negligible Solar Radiation
The Wet Bulb Globe Temperature (WBGT) can be calculated for indoor conditions as
WBGT = 0.7 Tnwb + 0.3 Tg                            (2)
Air Psychrometrics
Physiology
Human physiology, air quality and comfort temperatures, activity and metabolic rates, health effects of carbon monoxide and more.
Compressible Gas Flow - Entropy
Calculating the entropy in a compressible gas flow.
Dry Bulb, Wet Bulb and Dew Point Temperatures
Dry Bulb, Wet Bulb and Dew Point temperatures can be used to determine the state of humid air.
Heat Index
Equivalent heat index vs. air temperature and relative humidity - in degrees Fahrenheit and Celsius.
Indoor Comfort Temperatures vs. Outdoor Temperatures
Recommended indoor comfort temperatures vs. outdoor temperatures.
Indoor Conditions - Summer or Winter
Recommended indoor design conditions summer or winter.
Metabolic Heat Gain from Persons
Human metabolic heat gain in air conditioned rooms.
Moist Air - Psychrometric Terms
Dry and wet bulb temperature, specific volume, relative humidity,  enthalpy and more.
Moist Air - Relative Humidity
Relative humidity in moist air is the ratio of partial vapor pressure to air pressure.
Moist Air - Water Vapor and Saturation Pressure
Saturation pressure of water vapor in moist air vs. temperature.
Predicted Mean Vote Index (PMV)
PMV index predicts mean comfort response of a larger group of people.
Solar Heat Transmission through Windows
Solar heat gain through windows with roller shades, vertical blinds and Venetian blinds
The Wet Bulb Globe Temperature can be used to measure the general Heat-Stress index.
