Predicted Mean Vote Index (PMV)
The PMV index predicts the mean response of a larger group of people according the ASHRAE thermal sense scale:
+3 hot
+2 warm
+1 slightly warm
0 neutral
-1 slightly cool
-2 cool
-3 cold
The PMV index is expressed by P.O. Fanger as
PMV = (0.303 e-0.036M + 0.028) L                            (1)
PMV = Predicted Mean Vote Index
M = metabolic rate
L = thermal load - defined as the difference between the internal heat production and the heat loss to the actual environment  - for a person at comfort skin temperature and evaporative heat loss by sweating at the actual activity level
PPD - Predicted Percentage Dissatisfied Index
Predicted Percentage Dissatisfied - PPD - index is a quantitative measure of the thermal comfort of a group of people at a particular thermal environment.
Note! - at least aprox. 5% of people in a group will be dissatisfied with the thermal climate - even with PMV = 0.
Physiology
Clo - Clothing and Thermal Insulation
Clo is used as a measure of clothes thermal insulation.
Discomfort Index
Comfort vs. dry bulb, wet bulb and dew point temperature.
Globe Temperature
The resultant or globe temperature.
Heat Index
Equivalent heat index vs. air temperature and relative humidity - in degrees Fahrenheit and Celsius.
Heat Index vs. Humidity
The influence of humidity on the apparent temperature and the heat index.
Human Body - Specific Heat
Specific heat of the human body - compared to substances like protein and wood.
Met - Human Metabolic Rates
Metabiolic Rate - Met - is used as a measuring unit for human body heat or power production.
Metabolic Heat Gain from Persons
Human metabolic heat gain in air conditioned rooms.
Percentage
Working with relative values.
pH in Human Biological Material
pH in human materials like blood, salvia and more.
Physiology - Activity and Metabolic Rates
Heat production from the human body vs. activity.
Wet Bulb Globe Temperature (WBGT)
The Wet Bulb Globe Temperature can be used to measure the general Heat-Stress index.
