pH in Human Biological Material
Typical pH ranges for human biological fluids:
Material | pH |
Bile | 6.8 - 7.0 |
Blood | 7.35 - 7.45 |
Duodenal contents | 4.8 - 8.2 |
Feces | 4.6 - 8.4 |
Gastric contents | 1.0 - 3.0 |
Milk | 6.6 - 7.6 |
Salvia | 6.5 - 7.5 |
Spinal fluid | 7.3 - 7.5 |
Urine | 4.8 - 8.4 |
Acid and Base pH Indicators
pH range vs. color change for acid and base indicators - together with pKa and structures of the indicators.
Age and Physical Growth - Weight and Height
Age and typical physical growth of boys and girls - age 2 to 18 years.
Blood Sugar Units
Convert between blood sugar units.
Bodies - Weight vs. Height
Typical ideal body weight versus height.
Carbon Dioxide Concentration - Comfort Levels
CO2 acceptance and comfort level.
Carbon Dioxide Emission from the Human Body vs. Activity
Carbon Dioxide emission from persons vs. activity.
Clothing, Activity and Human Metabolism
Human metabolism at low and high activity with different levels of clothing.
Food and Foodstuff - pH Values
pH in common food products - like apples, butter, wines and more.
Force, Power and Human Operated Machines
Maximum force or power available in human operated machines.
Human Body - Specific Heat
Specific heat of the human body - compared to substances like protein and wood.
Human Body Composition
Composition of the human body.
Human Effects when Exposed to Low-Frequency Noise or Vibration
Physiological effects from low-frequency noise or vibrations.
Human Effort Levels - Energy and Heart Rates
Human work effort levels vs. energy expenditure and associated heart rates.
Human Heat Gain
Heat gain from persons in air conditioned spaces - in btu/hr.
Human Need of Air
Fresh air is required for respiration and for transport of heat and vapor emitted from the human body.
Met - Human Metabolic Rates
Metabiolic Rate - Met - is used as a measuring unit for human body heat or power production.
Metabolic Heat Gain from Persons
Human metabolic heat gain in air conditioned rooms.
pH - Basic (alkaline) vs. Acidic
Introduction to pH - the acidic and basic (alkaline) definition.
Predicted Mean Vote Index (PMV)
PMV index predicts mean comfort response of a larger group of people.
Recommended Relative Humidity
Recommended relative humidity level.
Survival Time in Cold Water
Time to exhaustion and death for humans in cold water.
