(btu/hr)
Human physiology, air quality and comfort temperatures, activity and metabolic rates, health effects of carbon monoxide and more.
Age and typical physical growth of boys and girls - age 2 to 18 years.
Typical ideal body weight versus height.
Latent and sensible cooling loads to consider when designing HVAC systems.
Typical power consumption and running time for common electrical equipment.
Gaseous polutants emissions from human bodies.
Maximum work load vs. temperature and relative humidity.
Heat contributed by lights may have major impact on air-condition systems.
Equivalent heat index vs. air temperature and relative humidity - in degrees Fahrenheit and Celsius.
The influence of humidity on the apparent temperature and the heat index.
Heat loss from electrical equipment like switch-gear, transformers and variable frequency drives.
Specific heat of the human body - compared to substances like protein and wood.
Composition of the human body.
Fresh air is required for respiration and for transport of heat and vapor emitted from the human body.
Relaxation rest time vs. working time and activity.
Calculate sensible and latent heat from persons, lights, electric equipment, machines, evaporation from water surfaces, polluting fluids and miscellaneous loads.
Human metabolic heat gain in air conditioned rooms.
pH in human materials like blood, salvia and more.
Heat production from the human body vs. activity.
Room area per person - may be used to calculate typical indoor climate loads.
Room Sensible Heat Factor - RSHF - is defined as the sensible heat load divided by the total heat load in a room
Time to exhaustion and death for humans in cold water.
