Human Body - Specific Heat
THe specific heat of the human body compared to protein and wood:
Human Body Substances - Specific Heats
SubstanceSpecific Heat
- cp-
(J/(kg oC))
Human Body (average) 3470
Protein 1700
Wood 1700
  • 1 J/(kg oC) = 2.389x10-4 kcal/(kg oC) = 2.389x10-4 Btu/(lbm oF)
Up to 60% of the human adult body is water. Specific heat of water is 4187 J/kg oC (1 Btu/lbm oF).
Material Properties
Age and Physical Growth - Weight and Height
Age and typical physical growth of boys and girls - age 2 to 18 years.
Blood Sugar Units
Convert between blood sugar units.
Bodies - Weight vs. Height
Typical ideal body weight versus height.
Carbon Dioxide Emission from the Human Body vs. Activity
Carbon Dioxide emission from persons vs. activity.
Clothing, Activity and Human Metabolism
Human metabolism at low and high activity with different levels of clothing.
Emissions from the Human Body
Gaseous polutants emissions from human bodies.
Heat Index
Equivalent heat index vs. air temperature and relative humidity - in degrees Fahrenheit and Celsius.
Heat Index vs. Humidity
The influence of humidity on the apparent temperature and the heat index.
Human Body Composition
Composition of the human body.
Human Effort Levels - Energy and Heart Rates
Human work effort levels vs. energy expenditure and associated heart rates.
Human Heat Gain
Heat gain from persons in air conditioned spaces - in btu/hr.
Human Need of Air
Fresh air is required for respiration and for transport of heat and vapor emitted from the human body.
Met - Human Metabolic Rates
Metabiolic Rate - Met - is used as a measuring unit for human body heat or power production.
Metabolic Heat Gain from Persons
Human metabolic heat gain in air conditioned rooms.
pH in Human Biological Material
pH in human materials like blood, salvia and more.
Predicted Mean Vote Index (PMV)
PMV index predicts mean comfort response of a larger group of people.
Recommended Relative Humidity
Recommended relative humidity level.
Survival Time in Cold Water
Time to exhaustion and death for humans in cold water.
