Carbon Dioxide Emission from the Human Body vs. Activity
The Carbon Dioxide - CO2 - concentration in a room with people can be used to indicate ventilation system efficiency. It is even possible to modulate ventilation system capacities to the number of people and their activities by measuring the carbon dioxide concentration in the room air.
Carbon dioxide emission from persons and their activity:
ActivityRespiration per Person
(m3/h)
Carbon Dioxide Emission per Person
(m3/h)
Sleep 0.3 0.013
Resting or low activity work 0.5 0.02
Normal work 2 - 3 0.08 - 0.13
Hard work 7 - 8 0.33 - 0.38
  • 1 m3/h = 0.5886 ft3/min (cfm)
Example - Carbon Dioxide Emission from Persons in a Cinema
In a cinema with 100 persons with low to normal activity the emission of carbon dioxide is in the range 0.02 to 0.08 m3/h per person and the the total emission will be in the range 2 to 8 m3/h.
Physiology
Age and Physical Growth - Weight and Height
Age and typical physical growth of boys and girls - age 2 to 18 years.
Bodies - Weight vs. Height
Typical ideal body weight versus height.
Carbon Dioxide - CO2 - Liquid - Properties, Imperial Units
Properties of saturated liquid Carbon Dioxide - CO2 - density, specific heat, kinematic viscosity, thermal conductivity and Prandtl number.
Carbon Dioxide - Liquid Properties
Carbon Dioxide - Specific Heat of Gas vs. Temperature
Specific heat of Carbon Dioxide gas - CO2 - temperatures ranging 175 - 6000 K.
Carbon Dioxide - Thermophysical Properties
Carbon Dioxide Concentration - Comfort Levels
CO2 acceptance and comfort level.
Carbon Dioxide Concentration in Rooms Occupied with People
Carbon dioxide concentration in a room may indicate air quality and ventilation system efficiency.
CO2 Calculator - Emissions from Trains
Calculator for CO2 emissions from trains, comparing with alternative forms of transportation (as plane, bus, conventional and electrical cars).
CO2 Calculator - Emissions from Airplanes
Calculator for CO2 emissions from planes, comparing with alternative forms of transportation (as train, bus, conventional and electrical cars).
CO2 Calculator - Emissions from Cars
Calculator for CO2 emissions from different kind of cars (gasoline, diesel, LPG, electrical), comparing with alternative forms of transportation (as airplane, bus and train).
Concentration of Carbon Dioxide in the Atmosphere
The atmospheric Carbon Dioxide concentration year 1959 - 2015.
Emissions from the Human Body
Gaseous polutants emissions from human bodies.
Heat Index vs. Humidity
The influence of humidity on the apparent temperature and the heat index.
Human Body - Specific Heat
Specific heat of the human body - compared to substances like protein and wood.
Humans - Required Rest Time
Relaxation rest time vs. working time and activity.
pH in Human Biological Material
pH in human materials like blood, salvia and more.
Required Building Space per Person
Room area per person - may be used to calculate typical indoor climate loads.
