Carbon Dioxide Concentration - Comfort Levels
Indoor comfort and air quality includes parameters like
- temperature
- odor
- high or low levels of gases
Since CO2 is exhaled by people at predictable levels the content of Carbon Dioxide in the indoor air can be used as a significant indication of air quality.
Fresh supply air correlates to the indoor level of CO2 as:
- 15 cfm ventilation rate per occupant - aprox. 1000 ppm CO2
- 20 cfm ventilation rate per occupant - aprox. 800 ppm CO2
Normal CO2 Levels
The effects of CO2 on adults at good health can be summarized to:
- normal outdoor level: 350 - 450 ppm
- acceptable levels: < 600 ppm
- complaints of stuffiness and odors: 600 - 1000 ppm
- ASHRAE and OSHA standards: 1000 ppm
- general drowsiness: 1000 - 2500 ppm
- adverse health effects may be expected: 2500 - 5000 ppm
- maximum allowed concentration within a 8 hour working period: 5000 - 10000 ppm
- maximum allowed concentration within a 15 minute working period: 30000 ppm
The levels above are quite normal and maximum levels may occasionally happen from time to time. In general - ventilation rates should keep carbon dioxide concentrations below 1000 ppm to create indoor air quality conditions acceptable to most individuals.
Extreme and Dangerous CO2 Levels
- slightly intoxicating, breathing and pulse rate increase, nausea: 30000 - 40000 ppm
- above plus headaches and sight impairment: 50000 ppm
- unconscious, further exposure death: 100000 ppm
Carbon Dioxide Standard Levels
The recommendations in ASHRAE standard 62-1989 are
- classrooms and conference rooms 15 cfm per occupant (person)
- office space and restaurants 20 cfm per occupant
- hospitals 25 cfm per occupant
- 1 cfm (ft3/min) = 1.7 m3/h = 0.47 l/s
• Physiology
Air Contaminants - Exposure Limits
Exposure limits for various air contaminants.
Ammonia and health symptoms - smell and threat to life.
Carbon Dioxide - CO2 - Liquid - Properties, Imperial Units
Properties of saturated liquid Carbon Dioxide - CO2 - density, specific heat, kinematic viscosity, thermal conductivity and Prandtl number.
Carbon Dioxide - Liquid Properties
Carbon Dioxide - Specific Heat of Gas vs. Temperature
Specific heat of Carbon Dioxide gas - CO2 - temperatures ranging 175 - 6000 K.
Carbon Dioxide - Thermophysical Properties
Carbon Dioxide Concentration in Rooms Occupied with People
Carbon dioxide concentration in a room may indicate air quality and ventilation system efficiency.
Carbon Dioxide Emission from the Human Body vs. Activity
Carbon Dioxide emission from persons vs. activity.
Chemicals Hazard Rating System
The National Fire Protection Association (NFPA) hazard system for chemical materials.
Clo - Clothing and Thermal Insulation
Clo is used as a measure of clothes thermal insulation.
Concentration of Carbon Dioxide in the Atmosphere
The atmospheric Carbon Dioxide concentration year 1959 - 2015.
Gases - Dangerous Concentration Levels
Dangerous vs. tolerable concentration levels for some industrial gases.
Heat Index
Equivalent heat index vs. air temperature and relative humidity - in degrees Fahrenheit and Celsius.
Heat Index vs. Humidity
The influence of humidity on the apparent temperature and the heat index.
Human Life Expectancy
Age and life expectancy for men and women.
Human Need of Air
Fresh air is required for respiration and for transport of heat and vapor emitted from the human body.
Odor from Persons - Required Ventilation
Required air ventilation to handle odor and smell from persons.
pH in Human Biological Material
pH in human materials like blood, salvia and more.
