Carbon Dioxide - Liquid Properties
Properties of saturated liquid Carbon Dioxide - CO2 - density, specific heat capacity, kinematic viscosity, thermal conductivity and Prandtl number:
Temperature - T - (oC) | Density - ρ - (kg/m3) | Specific Heat - cp - (103 J/kg K) | Thermal Conductivity - k - (W/m K) | Kinematic Viscosity - ν - (10-6 m2/s) | Prandtl's No. - Pr - |
-50 | 1156 | 1.84 | 0.086 | 0.119 | 2.96 |
-40 | 1118 | 1.88 | 0.101 | 0.118 | 2.46 |
-30 | 1077 | 1.97 | 0.112 | 0.117 | 2.22 |
-20 | 1032 | 2.05 | 0.115 | 0.115 | 2.12 |
-10 | 983 | 2.18 | 0.110 | 0.113 | 2.20 |
0 | 927 | 2.47 | 0.105 | 0.108 | 2.38 |
10 | 860 | 3.14 | 0.097 | 0.101 | 2.80 |
20 | 773 | 5.0 | 0.087 | 0.091 | 4.10 |
30 | 598 | 36.4 | 0.070 | 0.080 | 28.7 |
- 1 kg/m3 = 0.0624 lb/ft3
- 1 J/(kg K) = 2.389×10-4 kcal/(kg oC) = 2.389×10-4 Btu/lbmoF
- 1 W/(m K) = 0.85984 kcal/(h m oC) = 0.5779 Btu/(ft h oF) = 0.048 Btu/(in h oF)
- 1 m2/s = 104 St = 106 cSt = 10.764 ft2/s= 38750 ft2/h
Carbon dioxide gas is produced from the combustion of coal or hydrocarbons, by fermentation of liquids and the breathing of humans and animals, and by volcanoes.
Carbon dioxide is at a low concentration in the atmosphere and acts as a greenhouse gas. Carbon dioxide is used by plants to produce carbohydrates where the photosynthesis process releases oxygen to the atmosphere.
Carbon dioxide gas is colorless and heavier than air and has a slightly irritating odor.
Freezing point is -78.5 oC where it forms carbon dioxide snow or "dry ice".
Solubility of CO2 in Water
- liquid mol fraction CO2×103
Carbon Dioxide (CO₂) Properties & Characteristics: Density, Thermal Data & More
Carbon Dioxide - CO2 - Liquid - Properties, Imperial Units
Properties of saturated liquid Carbon Dioxide - CO2 - density, specific heat, kinematic viscosity, thermal conductivity and Prandtl number.
Carbon Dioxide - Specific Heat of Gas vs. Temperature
Specific heat of Carbon Dioxide gas - CO2 - temperatures ranging 175 - 6000 K.
Online calculator, figures and table showing thermal conductivity of carbon dioxide, CO2, at temperatures ranging from -50 to 775 °C (-50 to 1400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Carbon Dioxide Concentration - Comfort Levels
CO2 acceptance and comfort level.
Carbon Dioxide Concentration in Rooms Occupied with People
Carbon dioxide concentration in a room may indicate air quality and ventilation system efficiency.
Carbon Dioxide Emission from the Human Body vs. Activity
Carbon Dioxide emission from persons vs. activity.
Carbon Dioxide Gas - Ideal Properties
Enthalpy, Entropy and Internal Energy of Carbon Dioxide gas.
CO2 Calculator - Emissions from Trains
Calculator for CO2 emissions from trains, comparing with alternative forms of transportation (as plane, bus, conventional and electrical cars).
CO2 Calculator - Emissions from Airplanes
Calculator for CO2 emissions from planes, comparing with alternative forms of transportation (as train, bus, conventional and electrical cars).
Combustion of Fuels - Carbon Dioxide Emission
Environmental emission of carbon dioxide CO2 when combustion fuels like coal, oil, natural gas, LPG and bio energy.
Concentration of Carbon Dioxide in the Atmosphere
The atmospheric Carbon Dioxide concentration year 1959 - 2015.
Helium - Thermophysical Properties
Chemical, Physical and Thermal Properties of Helium - He.
Prandtl Number
A dimensionless number approximating the ratio of momentum diffusivity to thermal diffusivity.
