Carbon Dioxide Gas - Ideal Properties
Enthalpy, Entropy and Internal Energy of Carbon Dioxide - CO2 - are indicated below.
Gases and Compressed Air
Carbon Dioxide (CO₂) Properties & Characteristics: Density, Thermal Data & More
Carbon Dioxide - CO2 - Liquid - Properties, Imperial Units
Properties of saturated liquid Carbon Dioxide - CO2 - density, specific heat, kinematic viscosity, thermal conductivity and Prandtl number.
Carbon Dioxide - Liquid Properties
Online calculator, figures and table showing thermal conductivity of carbon dioxide, CO2, at temperatures ranging from -50 to 775 °C (-50 to 1400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Mole and the Avagadro's Number
The mole is the SI base unit for an amount of a substance.
