Carbon Dioxide (CO₂) Properties & Characteristics: Density, Thermal Data & More
Carbon dioxide, CO2, is a colourless and odorless gas. It is relatively nontoxic and noncombustible, but it is heavier than air and may asphyxiate by the displacement of air.
When CO2is solved in water, the mild carbonic acid , is formed. Cooled CO2in solid form is called dry ice.
Carbon dioxide phase diagram
Chemical, physical and thermal properties of carbon dioxide : Values are given for gas phase at 25 oC (77 oF, 298 K) and 1 atm, if not other phase, temperature or pressure given.
For full table with Imperial Units - rotate the screen!
Carbon Dioxide - Thermophysical Properties
Property Value Unit Value Unit Value Unit Value Unit
Acidity (pKa1) 6.35
Acidity (pKa2) 10.33
Boiling Point - sublimation point 194.686 K -78.464 °C -109.24 °F
Critical density 10.63 mol/dm3 467.6 kg/m3 0.9073 slug/ft3 29.19 lb/ft3
Critical pressure 7.38 MPa=MN/m2 73.8 bar 72.8 atm 1070 psi=lbf/in2
Critical temperature 304.13 K 30.98 °C 87.76 °F
Critical volume 94.12 cm3/mol 0.00214 m3/kg 1.102 ft3/slug 0.03426 ft3/lb
Density 40.8 mol/m3 1.795 kg/m3 0.00348 slug/ft3 0.1121 lb/ft3
Density, gas at 32°F/0°C 1 atm 44.9 mol/m3 1.977 kg/m3 0.00384 slug/ft3 0.1234 lb/ft3
Density, liquid at -34.6 °F/-37°C, saturation pressure 25017 mol/m3 1101 kg/m3 2.136 slug/ft3 68.73 lb/ft3
Density, solid at -109.3 °F/-78.5°C, 1 atm 35492 mol/m3 1562 kg/m3 3.031 slug/ft3 97.51 lb/ft3
Flammable no
Gas constant - R (individual) 188.92 J/kg K 0.0525 Wh/(kg K) 1130 (ft lbf/slug °R) 35.114 (ft lbf/lb °R)
Gibbs free energy of formation -394.00 kJ/mol -8953 kJ/kg -3849 Btu/lb
Heat (enthalpy) of combustion 0 kJ/mol 0 kJ/kg 0 Btu/lb
Heat (enthalpy) of formation -393.50 kJ/mol -8941 kJ/kg -3844 Btu/lb
Heat (enthalpy) of fusion 9.02 kJ/mol 205 kJ/kg 88.11 Btu/lb
Heat (enthalpy) of sublimation, at 180 K 26 kJ/mol 591 kJ/kg 254 Btu/lb
Heat (enthalpy) of vaporization at 15°C 179.5 kJ/kg 77.2 Btu/lb
Heat (enthalpy) of vaporization at triple point 15.55 kJ/mol 353.4 kJ/kg 151.93 Btu/lb
Specific heat capacity, Cp (isobaric) 37.35 J/mol K 0.849 kJ/kg K 0.203 Btu/lb°F or cal/g K
Specific heat capacity, Cv (isochoric) 28.96 J/mol K 0.658 kJ/kg K 0.157 Btu/lb°F or cal/g K
Ionization potential 13.77 eV
Molecular Weight 44.0095 g/mol 0.09702 lb/mol
pH of saturated aqueous solution 3.7
Solubility in water 0.148 g/100 g 1.48 g/l=mg/ml
Sound velocity in gas 269 m/s
Specific Gravity (density relativ to density of air) 1.53
Specific Heat Ratio - Cp/Cv 1.29
Specific Volume 0.0245 m3/mol 0.557 m3/kg 287.1 ft3/slug 8.92 ft3/lb
Standard molar entropy, S° 213.8 J/mol K 4.86 kJ/kg K 1.16 Btu/lb °F
Sublimation Point 194.686 K -78.464 °C -109.24 °F
Surface tension at melting point 16.2 dynes/cm
Thermal Conductivity 0.01663 W/m°C 0.009609 Btu/hr ft °F
Triple point pressure 0.5180 MPa=MN/m2 5.180 bar 5.112 atm 75.12 psi=lbf/in2
Triple point temperature 216.58 K -56.57 °C -69.81 °F
Vapor (saturation) pressure 6.45 MPa=MN/m2 48379 mm Hg 63.66 atm 935.5 psi=lbf/in2
Viscosity, dynamic (absolute) 1.495 cP 1004.6 (lbm/ft s ×10-6) 31.22 (lbf s/ft2 ×10-6)
Viscosity, kinematic 0.834 cSt 8.977 (ft2/s ×10-6)
Follow the links below to get values for the listed properties of carbon dioxide at varying pressure and temperature :
as well as Thermophysical properties of: Acetone, Acetylene, Air, Ammonia, Argon, Benzene, Butane, Carbon monoxide, Ethane, Ethanol, Ethylene, Helium, Hydrogen, Hydrogen sulfide, Methane, Methanol, Nitrogen, Oxygen, Pentane, Propane, Toluene, Water and Heavy water, D2O.
Carbon dioxide is a gas at standard conditions. However, at low temperature and/or high pressures the gas becomes a liquid or a solid.
The phase diagram for carbon dioxide shows the phase behavior with changes in temperature and pressure. The curve between the critical point and the triple point shows the carbon dioxide boiling point with changes in pressure. The curve between the triple point downwards to zero pressure shows the sublimation point with changes in pressure (Sublimation: transformation from solid phase directly to gas phase). Carbon dioxide in solid phase is called dry ice.
Atmospheric CO2Concentration
Boiling Points of Fluids
Densities
Fluid Mechanics
Material Properties
Melting and Freezing Points
Thermodynamics
Viscosities
Carbon Dioxide - CO2 - Liquid - Properties, Imperial Units
Properties of saturated liquid Carbon Dioxide - CO2 - density, specific heat, kinematic viscosity, thermal conductivity and Prandtl number.
Carbon Dioxide - Liquid Properties
Carbon Dioxide - Specific Heat of Gas vs. Temperature
Specific heat of Carbon Dioxide gas - CO2 - temperatures ranging 175 - 6000 K.
Online calculator, figures and table showing thermal conductivity of carbon dioxide, CO2, at temperatures ranging from -50 to 775 °C (-50 to 1400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Carbon Dioxide Concentration - Comfort Levels
CO2 acceptance and comfort level.
Carbon Dioxide Concentration in Rooms Occupied with People
Carbon dioxide concentration in a room may indicate air quality and ventilation system efficiency.
Carbon Dioxide Emission from the Human Body vs. Activity
Carbon Dioxide emission from persons vs. activity.
Carbon Dioxide Gas - Ideal Properties
Enthalpy, Entropy and Internal Energy of Carbon Dioxide gas.
CO2 Calculator - Emissions from Trains
Calculator for CO2 emissions from trains, comparing with alternative forms of transportation (as plane, bus, conventional and electrical cars).
CO2 Calculator - Emissions from Airplanes
Calculator for CO2 emissions from planes, comparing with alternative forms of transportation (as train, bus, conventional and electrical cars).
CO2 Calculator - Emissions from Cars
Calculator for CO2 emissions from different kind of cars (gasoline, diesel, LPG, electrical), comparing with alternative forms of transportation (as airplane, bus and train).
Combustion Efficiency and Excess Air
Optimizing boilers efficiency is important to minimize fuel consumption and unwanted excess to the environment.
Combustion of Fuels - Carbon Dioxide Emission
Environmental emission of carbon dioxide CO2 when combustion fuels like coal, oil, natural gas, LPG and bio energy.
Concentration of Carbon Dioxide in the Atmosphere
The atmospheric Carbon Dioxide concentration year 1959 - 2015.
Gases - Dynamic Viscosities
Absolute (dynamic) viscosities of some common gases.
Gases - Specific Gravities
Specific gravities of air, ammonia, butadiene, carbon dioxide, carbon monoxide and some other common gases.
Gases - Speed of Sound
Speed of sound in some gases at zero degrees Celsius and atmospheric pressure.
Methane (CH₄): Thermophysical Properties and Phase Diagram
Methanol - Thermophysical Properties
Chemical, physical and thermal properties of methanol, CH3OH (also called carbinol, wood alcohol, hydroxy methyl and methyl alcohol). Phase diagram included.
Thermal Conductivity of Common Materials - Solids, Liquids and Gases
Thermal conductivity of various common materials, including metals, gases, and building materials. Essential data for engineers, architects, and designers working with heat transfer and insulation.
