(values at 25 o C (77 o F, 298 K) and atmospheric pressure)
Molecular Weight | 28.011 |
Specific Gravity , air = 1 | 0.967 |
Specific Volume ( ft 3 /lb, m 3 /kg ) | 14.0, 0.874 |
Absolute Viscosity ( lb m /ft s, centipoises ) | 12.1 10 -6 , 0.018 |
Sound velocity in gas ( m/s ) | 352 |
Specific Heat - c p - ( Btu/lb o F or cal/g o C, J/kgK ) | 0.25, 1046 |
Specific Heat Ratio - c p /c v | 1.40 |
Gas constant - R - ( ft lb/lb o R, J/kg o C ) | 55.2, 297 |
Thermal Conductivity ( Btu/hr ft o F, W/m o C ) | 0.014, 0.024 |
Boiling Point - saturation pressure 14.7 psia and 760 mm Hg - ( o F, o C ) | -312.7, -191.5 |
Latent Heat of Evaporation at boiling point ( Btu/lb, J/kg ) | 92.8, 216000 |
Freezing or Melting Point at 1 atm ( o F, o C ) | -337, -205 |
Latent Heat of Fusion ( Btu/lb, J/kg ) | 12.8 |
Critical Temperature ( o F, o C ) | -220, -140 |
Critical Pressure ( psia, MN/m 2 ) | 507, 3.49 |
Critical Volume ( ft 3 /lb, m 3 /kg ) | 0.053, 0.0033 |
Flammable | yes |
Heat of combustion ( Btu/ft 3 , Btu/lb, kJ/kg ) | 310, 4340, 10100 |
Follow the links below to get values for the listed properties of carbon monooxide at varying pressure and temperature :
as well as Thermophysical properties of: Acetone , Acetylene , Air , Ammonia , Argon , Benzene , Butane , Carbon dioxide , Ethane , Ethanol , Ethylene , Helium , Hydrogen , Hydrogen sulfide , Methane , Methanol , Nitrogen , Oxygen , Pentane , Propane , Toluene , Water and Heavy water, D 2 O .
Exposure to Carbon Monoxide - CO and health effects.
Carbon Monoxide Gas - CO - specific heat of at temperatures ranging 175 - 6000 K.
Dangerous vs. tolerable concentration levels for some industrial gases.
