Nitrogen, N2, is at standard conditions a colorless odorless gas. The gas makes up the major portion of the atmosphere, but will not support life by itself. Refrigerated (cryogenic) nitrogen, is a colorless odorless liquid.
Gaseous nitrogen is used in food processing, in purging air conditioning and refrigeration systems, and in pressurizing aircraft tires. Liquid nitrogen is used to freeze foods, to preserve whole blood and other biologicals, and as a coolant.
Nitrogen is nontoxic and noncombustible, but it may cause asphyxiation by displacement of air. Liquid nitrogen is very cold and and contact may cause frostbite. Under prolonged exposure to fire or heat, nitrogen containers may rupture violently and rocket.
The phase diagram of nitrogen is shown below the table.
Chemical, physical and thermal properties of Nitrogen:
Values at 25 oC (77 oF, 298 K) and atmospheric pressure
| Molecular Weight | 28.013 |
| Specific Gravity, air = 1 | 0.967 |
| Specific Volume (ft3/lb, m3/kg) | 13.98, 0.872 |
| Density of liquid at atmospheric pressure (lb/ft3, kg/m3) | 50.46, 808.4 |
| Absolute Viscosity (lbm/ft s, centipoises) | 12.1×10-6, 0.018 |
| Sound velocity in gas (m/s) | 353 |
| Specific Heat - cp - (Btu/lb oF or cal/g oC, J/kgK) | 0.249, 1040 |
| Specific Heat Ratio - cp/cv | 1.40 |
| Gas constant - R - (ft lb/lb oR, J/kg oC) | 55.2, 297 |
| Thermal Conductivity (Btu/hr ft oF, W/moC) | 0.015, 0.026 |
| Boiling Point - at saturation pressure 14.7 psia and 760 mm Hg - (oF, oC) | -320.4, -195.8 |
| Latent Heat of Evaporation at boiling point (Btu/lb, J/kg) | 85.5, 199000 |
| Freezing or Melting Point at 1 atm (oF, oC) | -346, -210 |
| Latent Heat of Fusion (Btu/lb, J/kg) | 11.1, 25800 |
| Critical Temperature (oF, oC) | -232.6, -147 |
| Critical Pressure (psia, MN/m2) | 493, 3.40 |
| Critical Volume (ft3/lb, m3/kg) | 0.051, 0.00318 |
| Flammable | no |
Follow the links below to get values for the listed properties of nitrogen at varying pressure and temperature :
- Density and specific weight
- Dynamic and kinematic viscosity
- Prandtl number
- Specific heat (heat capacity)
- Thermal conductivity
- Thermal diffusivity
as well as Thermophysical properties of: Acetone, Acetylene, Air, Ammonia, Argon, Benzene, Butane, Carbon dioxide, Carbon monoxide, Ethane, Ethanol, Ethylene, Helium, Hydrogen, Hydrogen sulfide, Methane, Methanol, Oxygen, Pentane, Propane, Toluene, Water and Heavy water, D2O.
Nitrogen is a gas at standard conditions. However, at low temperature and/or high pressures the gas becomes a liquid or a solid.
The nitrogen phase diagram shows the phase behavior with changes in temperature and pressure. The curve between the critical point and the triple point shows the nitrogen boiling point with changes in pressure. It also shows the saturation pressure with changes in temperature.
• Boiling Points of Fluids
• Densities
• Melting and Freezing Points
• Thermodynamics
• Viscosities
Online calculator, figures and table showing density and specific weight of benzene, C6H6, at temperatures ranging from 5 to 325 °C (42 to 620 °F) at atmospheric and higher pressure - Imperial and SI Units.
Biogas - Carbon Nitrogen Ratios
Carbon - Nitrogen ratios for biogas produced from various raw materials.
Cryogenic Fluids and Liquefied Gas Properties
Cryogenic properties as density, boiling points and heat of evaporation for fluids like hydrogen, methane, oxygen, nitrogen, fluorine and helium.
Gases - Dynamic Viscosities
Absolute (dynamic) viscosities of some common gases.
Gases - Specific Heat and Individual Gas Constants
Liquids - Latent Heat of Evaporation
Latent heat of vaporization for fluids like alcohol, ether, nitrogen, water and more.
Nitrogen (N₂) Density & Specific Weight: Temperature & Pressure Data and Calculator
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Nitrogen - Enthalpy, Internal Energy and Entropy vs. Temperature
Enthalpy, internal energy and entropy of Nitrogen as an ideal gas.
Nitrogen - Thermal Diffusivity vs. Temperature and Pressure
Figures and tables showing thermal diffusivity of nitrogen at varying temperarure and pressure, SI and Imperial units.
Nitrogen Gas - Specific Heat vs. Temperature
Specific heat of Nitrogen Gas - N2 - at temperatures ranging 175 - 6000 K
Nitrogen Oxides (NOx) Emission from Fuels
Emission of Nitrogen Oxides - NOx - with combustion of fuels like oil, coal, propane and more.
