Nitrogen (N₂) Density & Specific Weight: Temperature & Pressure Data and Calculator
ρ = m / V (1)
γ = m g / V
= ρ g (2)
Tabulated values of nitrogen density at given temperature and pressure (SI and Imperial units) as well as density units conversion are given below the figures.
Online Nitrogen Density Calculator
The calculator below can be used to estimate the density and specific weight of gaseous nitrogen at given temperature and pressure.
Choose the actual pressure:
See also other properties of Nitrogen at varying temperature and pressure : Dynamic and kinematic viscosity, Prandtl number, Specific heat (Heat capacity), Thermal conductivity and thermal diffusivity, and thermophysical properties at standard conditions,
as well as density and specific weight o f acetone, air, ammonia, argon, benzene, butane, carbon dioxide, carbon monoxide, ethane, ethanol, ethylene, helium, hydrogen, methane, methanol, oxygen, pentane, propane, toluene and water .
Density and specific weight of nitrogen at given temperatures and pressures:
| (K) | (°C) | (°F) | (MPa) | (bara) | (psia) | (mol/dm3) | (g/l), (kg/m3) | (lbm/ft3) | (sl/ft3 ×10-3) | (N/m3) | (lbf/ft3) | |
Liquid at equilibrium pressure |
63.15 | -210.0 | -346.0 | 0.013 | 0.125 | 1.82 | 30.96 | 867.2 | 54.14 | 1683 | 8505 | 54.1 |
| 69 | -204 | -335 | 0.033 | 0.332 | 4.82 | 30.09 | 842.8 | 52.61 | 1635 | 8265 | 52.6 | |
| 75 | -198 | -325 | 0.076 | 0.760 | 11.0 | 29.15 | 816.7 | 50.98 | 1585 | 8009 | 51.0 | |
| 79 | -194 | -317 | 0.122 | 1.22 | 17.8 | 28.51 | 798.6 | 49.85 | 1549 | 7831 | 49.9 | |
| 85 | -188 | -307 | 0.229 | 2.29 | 33.2 | 27.49 | 770.2 | 48.08 | 1494 | 7553 | 48.1 | |
| 89 | -184 | -299 | 0.331 | 3.31 | 47.9 | 26.78 | 750.2 | 46.83 | 1456 | 7357 | 46.8 | |
| 95 | -178 | -289 | 0.541 | 5.41 | 78.4 | 25.64 | 718.3 | 44.84 | 1394 | 7044 | 44.8 | |
| 99 | -174 | -281 | 0.726 | 7.26 | 105 | 24.82 | 695.4 | 43.41 | 1349 | 6819 | 43.4 | |
| 105 | -168 | -271 | 1.08 | 10.8 | 157 | 23.47 | 657.5 | 41.05 | 1276 | 6448 | 41.0 | |
| 109 | -164 | -263 | 1.38 | 13.8 | 201 | 22.46 | 629.1 | 39.27 | 1221 | 6169 | 39.3 | |
| 115 | -158 | -253 | 1.94 | 19.4 | 281 | 20.66 | 578.7 | 36.13 | 1123 | 5675 | 36.1 | |
| 121 | -152 | -242 | 2.64 | 26.4 | 383 | 18.19 | 509.5 | 31.81 | 988.6 | 4996 | 31.8 | |
| 126.2 | -147.0 | -232.5 | 3.40 | 34.0 | 493 | 11.18 | 313.3 | 19.56 | 607.9 | 3073 | 19.6 | |
Gas at equlibrium pressure |
63.15 | -210.0 | -346.0 | 0.013 | 0.125 | 1.82 | 0.02407 | 0.6743 | 0.04210 | 1.308 | 6.61 | 0.0421 |
| 69 | -204 | -335 | 0.033 | 0.332 | 4.82 | 0.05903 | 1.654 | 0.1032 | 3.209 | 16.2 | 0.103 | |
| 75 | -198 | -325 | 0.076 | 0.760 | 11.0 | 0.1264 | 3.540 | 0.2210 | 6.870 | 34.7 | 0.221 | |
| 79 | -194 | -317 | 0.122 | 1.22 | 17.8 | 0.1961 | 5.494 | 0.3430 | 10.66 | 53.9 | 0.343 | |
| 85 | -188 | -307 | 0.229 | 2.29 | 33.2 | 0.3507 | 9.824 | 0.6133 | 19.06 | 96.3 | 0.613 | |
| 89 | -184 | -299 | 0.331 | 3.31 | 47.9 | 0.4958 | 13.89 | 0.8670 | 26.95 | 136 | 0.867 | |
| 95 | -178 | -289 | 0.541 | 5.41 | 78.4 | 0.7950 | 22.27 | 1.390 | 43.22 | 218 | 1.39 | |
| 99 | -174 | -281 | 0.726 | 7.26 | 105 | 1.063 | 29.79 | 1.860 | 57.80 | 292 | 1.86 | |
| 105 | -168 | -271 | 1.08 | 10.8 | 157 | 1.605 | 44.96 | 2.807 | 87.24 | 441 | 2.81 | |
| 109 | -164 | -263 | 1.38 | 13.8 | 201 | 2.092 | 58.59 | 3.658 | 113.7 | 575 | 3.66 | |
| 115 | -158 | -253 | 1.94 | 19.4 | 281 | 3.116 | 87.30 | 5.450 | 169.4 | 856 | 5.45 | |
| 121 | -152 | -242 | 2.64 | 26.4 | 383 | 4.838 | 135.5 | 8.461 | 263.0 | 1329 | 8.46 | |
| Gas | 100 | -173 | -280 | 0.1 | 1 | 14.5 | 0.1227 | 3.437 | 0.2145 | 6.668 | 33.7 | 0.215 |
| 150 | -123 | -190 | 0.1 | 1 | 14.5 | 0.08040 | 2.252 | 0.1406 | 4.370 | 22.1 | 0.141 | |
| 200 | -73.2 | -99.7 | 0.1 | 1 | 14.5 | 0.06030 | 1.689 | 0.1055 | 3.278 | 16.6 | 0.105 | |
| 300 | 26.9 | 80.3 | 0.1 | 1 | 14.5 | 0.04020 | 1.126 | 0.07030 | 2.185 | 11.0 | 0.0703 | |
| 400 | 127 | 260 | 0.1 | 1 | 14.5 | 0.03015 | 0.845 | 0.05273 | 1.639 | 8.28 | 0.0527 | |
| 500 | 227 | 440 | 0.1 | 1 | 14.5 | 0.02412 | 0.676 | 0.04218 | 1.311 | 6.63 | 0.0422 | |
| 600 | 327 | 620 | 0.1 | 1 | 14.5 | 0.02004 | 0.561 | 0.03504 | 1.089 | 5.50 | 0.0350 | |
| 800 | 527 | 980 | 0.1 | 1 | 14.5 | 0.01507 | 0.422 | 0.02636 | 0.8194 | 4.14 | 0.0264 | |
| 1100 | 827 | 1520 | 0.1 | 1 | 14.5 | 0.01093 | 0.306 | 0.01912 | 0.5941 | 3.00 | 0.0191 | |
| 1600 | 1327 | 2420 | 0.1 | 1 | 14.5 | 0.00752 | 0.211 | 0.01314 | 0.4085 | 2.06 | 0.0131 | |
| Liquid | 100 | -173 | -280 | 1 | 10 | 145 | 24.66 | 690.8 | 43.12 | 1340 | 6774 | 43.1 |
| 103.8 | -169.4 | -272.9 | 1 | 10 | 145 | 23.77 | 665.8 | 41.57 | 1292 | 6530 | 41.6 | |
| Gas | 103.8 | -169.4 | -272.9 | 1 | 10 | 145 | 1.475 | 41.33 | 2.580 | 80.20 | 405 | 2.58 |
| 150 | -123 | -190 | 1 | 10 | 145 | 0.8015 | 22.45 | 1.402 | 43.57 | 220 | 1.40 | |
| 200 | -73.2 | -99.7 | 1 | 10 | 145 | 0.6011 | 16.84 | 1.051 | 32.68 | 165 | 1.05 | |
| 300 | 26.9 | 80.3 | 1 | 10 | 145 | 0.4008 | 11.23 | 0.7009 | 21.78 | 110 | 0.701 | |
| 400 | 127 | 260 | 1 | 10 | 145 | 0.3006 | 8.420 | 0.5257 | 16.34 | 82.6 | 0.526 | |
| 500 | 227 | 440 | 1 | 10 | 145 | 0.2405 | 6.736 | 0.4205 | 13.07 | 66.1 | 0.421 | |
| 600 | 327 | 620 | 1 | 10 | 145 | 0.1996 | 5.592 | 0.3491 | 10.85 | 54.8 | 0.349 | |
| 800 | 527 | 980 | 1 | 10 | 145 | 0.1503 | 4.210 | 0.2628 | 8.169 | 41.3 | 0.263 | |
| 950 | 677 | 1250 | 1 | 10 | 145 | 0.1266 | 3.545 | 0.2213 | 6.879 | 34.8 | 0.221 | |
| 1100 | 827 | 1520 | 1 | 10 | 145 | 0.1090 | 3.053 | 0.1906 | 5.924 | 29.9 | 0.191 | |
| 1600 | 1327 | 2420 | 1 | 10 | 145 | 0.07499 | 2.101 | 0.1312 | 4.076 | 20.6 | 0.131 | |
| Gas | 150 | -123 | -190 | 3 | 30 | 435 | 2.405 | 67.36 | 4.205 | 130.7 | 661 | 4.21 |
| 200 | -73.2 | -99.7 | 3 | 30 | 435 | 1.803 | 50.52 | 3.154 | 98.03 | 495 | 3.15 | |
| 300 | 26.9 | 80.3 | 3 | 30 | 435 | 1.202 | 33.68 | 2.103 | 65.35 | 330 | 2.10 | |
| 400 | 127 | 260 | 3 | 30 | 435 | 0.9017 | 25.26 | 1.577 | 49.01 | 248 | 1.58 | |
| 500 | 227 | 440 | 3 | 30 | 435 | 0.7214 | 20.21 | 1.262 | 39.21 | 198 | 1.26 | |
| 600 | 327 | 620 | 3 | 30 | 435 | 0.6011 | 16.84 | 1.051 | 32.68 | 165 | 1.05 | |
| 700 | 427 | 800 | 3 | 30 | 435 | 0.5153 | 14.43 | 0.9011 | 28.01 | 142 | 0.901 | |
| 800 | 527 | 980 | 3 | 30 | 435 | 0.4509 | 12.63 | 0.7885 | 24.51 | 124 | 0.788 | |
| 950 | 677 | 1250 | 3 | 30 | 435 | 0.3797 | 10.64 | 0.6640 | 20.64 | 104 | 0.664 | |
| 1100 | 827 | 1520 | 3 | 30 | 435 | 0.3279 | 9.186 | 0.5734 | 17.82 | 90.1 | 0.573 | |
| 1600 | 1327 | 2420 | 3 | 30 | 435 | 0.2254 | 6.315 | 0.3942 | 12.25 | 61.9 | 0.394 | |
| Liquid | 100 | -173 | -280 | 5 | 50 | 725 | 25.44 | 712.6 | 44.48 | 1383 | 6988 | 44.5 |
Supercritical phase |
150 | -123 | -190 | 5 | 50 | 725 | 4.008 | 112.3 | 7.009 | 217.8 | 1101 | 7.01 |
| 200 | -73.2 | -99.7 | 5 | 50 | 725 | 3.006 | 84.20 | 5.257 | 163.4 | 826 | 5.26 | |
| 300 | 26.9 | 80.3 | 5 | 50 | 725 | 2.004 | 56.13 | 3.504 | 108.9 | 550 | 3.50 | |
| 400 | 127 | 260 | 5 | 50 | 725 | 1.503 | 42.10 | 2.628 | 81.69 | 413 | 2.63 | |
| 500 | 227 | 440 | 5 | 50 | 725 | 1.202 | 33.68 | 2.103 | 65.35 | 330 | 2.10 | |
| 600 | 327 | 620 | 5 | 50 | 725 | 0.9808 | 27.48 | 1.715 | 53.31 | 269 | 1.72 | |
| 1100 | 827 | 1520 | 5 | 50 | 725 | 0.5380 | 15.07 | 0.941 | 29.24 | 148 | 0.941 | |
| 1600 | 1327 | 2420 | 5 | 50 | 725 | 0.3715 | 10.41 | 0.650 | 20.19 | 102 | 0.650 | |
| Liquid | 100 | -173 | -280 | 10 | 100 | 1450 | 26.19 | 733.6 | 45.80 | 1423 | 7194 | 45.8 |
150 | -123 | -190 | 10 | 100 | 1450 | 8.015 | 224.5 | 14.02 | 435.7 | 2202 | 14.0 |
| 200 | -73.2 | -99.7 | 10 | 100 | 1450 | 6.011 | 168.4 | 10.51 | 326.8 | 1651 | 10.5 | |
| 300 | 26.9 | 80.3 | 10 | 100 | 1450 | 4.008 | 112.3 | 7.009 | 217.8 | 1101 | 7.01 | |
| 400 | 127 | 260 | 10 | 100 | 1450 | 3.006 | 84.20 | 5.257 | 163.4 | 826 | 5.26 | |
| 500 | 227 | 440 | 10 | 100 | 1450 | 2.405 | 67.36 | 4.205 | 130.7 | 661 | 4.21 | |
| 600 | 327 | 620 | 10 | 100 | 1450 | 1.918 | 53.74 | 3.355 | 104.3 | 527 | 3.35 | |
| 1100 | 827 | 1520 | 10 | 100 | 1450 | 1.059 | 29.67 | 1.852 | 57.56 | 291 | 1.85 | |
| 1600 | 1327 | 2420 | 10 | 100 | 1450 | 0.7344 | 20.57 | 1.284 | 39.92 | 202 | 1.28 | |
• Thermodynamics
Acetone - Density and Specific Weight
Online calculator, figures and tables showing density and specific weight of acetone at temperatures ranging from -95 to 275 °C (-138 to 530 °F) at atmospheric and higher pressure - Imperial and SI Units.
Online calculator, figures and table showing density and specific weight of benzene, C6H6, at temperatures ranging from 5 to 325 °C (42 to 620 °F) at atmospheric and higher pressure - Imperial and SI Units.
Density Converter
Gases - Dynamic Viscosities
Absolute (dynamic) viscosities of some common gases.
Liquids - Latent Heat of Evaporation
Latent heat of vaporization for fluids like alcohol, ether, nitrogen, water and more.
Mass vs. Weight
Online calculator, figures and tables showing density and specific weight of methanol,CH3OH, at varying temperature and pressure - Imperial and SI Units.
Nitrogen - Enthalpy, Internal Energy and Entropy vs. Temperature
Enthalpy, internal energy and entropy of Nitrogen as an ideal gas.
Nitrogen - Thermal Diffusivity vs. Temperature and Pressure
Figures and tables showing thermal diffusivity of nitrogen at varying temperarure and pressure, SI and Imperial units.
Nitrogen Gas - Specific Heat vs. Temperature
Specific heat of Nitrogen Gas - N2 - at temperatures ranging 175 - 6000 K
Nitrogen Oxides (NOx) Emission from Fuels
Emission of Nitrogen Oxides - NOx - with combustion of fuels like oil, coal, propane and more.
