Density , ρ, has units typically (kg/m3) or (lb/ft3), and is defined by the ratio of the mass to the volume of a substance:
ρ = m / V                                (1)
Specific weight , γ, has units typically (N/m3) or (lbf/ft3)  is defined by the ratio of the weight to the volume of a substance:
γ = m g / V
   = ρ g                                (2)
Tabulated values of ethylene density and specific weight at given temperature and pressure (SI and Imperial units) as well as density units conversion are given below the figures.
Online Ethylene Density Calculator
The calculator below can be used to estimate the density and specific weight of ethylene at given temperature and pressure.
The output density is given as kg/m3, lb/ft3, lb/gal(US liq) and sl/ft3.  Specific weight is given as N/m3 and lbf/ ft3.
Note that there will be a significant shift in density when going from liquid to gaseous phase of ethylene (below and above boiling point at given pressure)
Choose the actual unit of temperature: Choose the actual pressure: 1 bara / 14.5 psia; 10 bara / 145 psia; 50 bara / 725 psia;
See also other properties of Ethylene at varying temperature: Dynamic and kinematic viscosity, Specific heat (heat capacity) and Thermal conductivity,  and Thermophysical properties at standard conditions,
as well as density and specific weight o f acetone, air, ammonia, argon, benzene, butane, carbon dioxide, carbon monoxide, ethane, ethanol, ethylene, helium, hydrogen, methane, methanol, nitrogen, oxygen, pentane, propane, toluene and water .
Ethylene phase diagram
Density and specific weight of ethylene gas at varying temperature and atmospheric pressure, SI and Imperial units:
Density and specific weight of liquid ethylene at varying temperature and gas-liquid equilibrium pressure, SI and Imperial units:
Density of e thylene at varying temperature and pressure, SI and Imperial units:
Density of e thylene at varying temperature and equilibrium pressure, SI and Imperial units:
Density and specific weight of ethylene at given temperatures and pressures:
(K) (°C) (°F) (bara) (psia) (mol/dm3) (g/l),
(kg/m3)
(lb/ft3) (sl/ft3) (N/m3) (lbf/ft3)
Liquid at
equilibrium
103.99 -169.16 -272.49 1.22E-03 0.0177 23.33 654.6 40.86 1.270 6419 40.86
105 -168 -271 1.46E-03 0.0211 23.29 653.3 40.78 1.268 6407 40.78
115 -158 -253 6.97E-03 0.101 22.83 640.6 39.99 1.243 6282 39.99
125 -148 -235 0.0253 0.366 22.38 627.7 39.19 1.218 6156 39.19
135 -138 -217 0.0739 1.07 21.91 614.6 38.37 1.193 6027 38.37
145 -128 -199 0.183 2.66 21.44 601.3 37.54 1.167 5897 37.54
155 -118 -181 0.398 5.77 20.95 587.8 36.69 1.140 5764 36.69
165 -108 -163 0.777 11.3 20.46 573.9 35.82 1.113 5628 35.82
175 -98.2 -145 1.39 20.2 19.95 559.5 34.93 1.086 5487 34.93
185 -88.2 -127 2.33 33.9 19.42 544.7 34.01 1.057 5342 34.01
195 -78.2 -109 3.69 53.5 18.87 529.2 33.04 1.027 5190 33.04
205 -68.2 -90.7 5.56 80.7 18.29 513.0 32.02 0.9953 5031 32.02
215 -58.2 -72.7 8.05 117 17.67 495.7 30.95 0.9619 4861 30.95
225 -48.2 -54.7 11.3 164 17.01 477.2 29.79 0.9259 4680 29.79
235 -38.2 -36.7 15.3 223 16.29 457.0 28.53 0.8868 4482 28.53
245 -28.2 -18.7 20.4 296 15.49 434.5 27.12 0.8430 4261 27.12
255 -18.2 -0.7 26.5 384 14.56 408.5 25.50 0.7925 4006 25.50
265 -8.1 17.3 33.9 492 13.42 376.4 23.50 0.7304 3692 23.50
275 1.9 35.3 42.8 620 11.79 330.8 20.65 0.6419 3244 20.65
282.35 9.20 48.56 50.4 731 7.637 214.2 13.37 0.4157 2101 13.37
Gas at
equilibrium
103.99 -169.16 -272.49 1.22E-03 0.0177 1.41E-04 3.96E-03 2.47E-04 7.68E-06 0.03881 2.47E-04
105 -168 -271 1.46E-03 0.0211 1.67E-04 4.68E-03 2.92E-04 9.08E-06 0.04592 2.92E-04
115 -158 -253 6.97E-03 0.101 7.30E-04 0.02048 1.28E-03 3.97E-05 0.20083 1.28E-03
125 -148 -235 0.0253 0.366 2.44E-03 0.06835 4.27E-03 1.33E-04 0.6702 4.27E-03
135 -138 -217 0.0739 1.07 6.62E-03 0.1857 0.01159 3.60E-04 1.821 0.01159
145 -128 -199 0.183 2.66 0.01533 0.4301 0.02685 8.35E-04 4.218 0.02685
155 -118 -181 0.398 5.77 0.03138 0.8803 0.05495 1.71E-03 8.633 0.05495
165 -108 -163 0.777 11.3 0.05823 1.634 0.1020 3.17E-03 16.02 0.1020
175 -98.2 -145 1.39 20.2 0.1000 2.805 0.1751 5.44E-03 27.51 0.1751
185 -88.2 -127 2.33 33.9 0.1614 4.528 0.2827 0.00879 44.41 0.2827
195 -78.2 -109 3.69 53.5 0.2480 6.958 0.4344 0.01350 68.23 0.4344
205 -68.2 -90.7 5.56 80.7 0.3664 10.28 0.6416 0.01994 100.8 0.6416
215 -58.2 -72.7 8.05 117 0.5247 14.72 0.9189 0.02856 144.3 0.9189
225 -48.2 -54.7 11.3 164 0.7339 20.59 1.285 0.03995 201.9 1.285
235 -38.2 -36.7 15.3 223 1.009 28.31 1.767 0.05493 277.6 1.767
245 -28.2 -18.7 20.4 296 1.375 38.56 2.408 0.07483 378.2 2.408
255 -18.2 -0.7 26.5 384 1.872 52.51 3.278 0.1019 515.0 3.278
265 -8.1 17.3 33.9 492 2.589 72.62 4.533 0.1409 712.1 4.533
275 1.9 35.3 42.8 620 3.795 106.5 6.646 0.2066 1044 6.646
Liquid 150 -123.2 -190 1 14.5 21.20 594.6 37.12 1.154 5831 37.12
169.16 -103.99 -155.18 1 14.5 20.55 576.4 35.98 1.118 5652 35.98
Gas 169.16 -103.99 -155.18 1 14.5 0.07352 2.062 0.1288 4.00E-03 20.23 0.1288
225 -48.2 -54.7 1 14.5 0.05418 1.520 0.09489 2.95E-03 14.91 0.09489
300 26.9 80.3 1 14.5 0.04031 1.131 0.07060 2.19E-03 11.09 0.07059
375 102 215 1 14.5 0.03216 0.9022 0.05632 1.75E-03 8.847 0.05632
450 176.9 350 1 14.5 0.02676 0.7507 0.04686 1.46E-03 7.362 0.04686
Liquid 150 -123 -190 10 145 21.22 595.3 37.16 1.155 5838 37.16
221.33 -51.82 -61.28 10 145 17.26 484.2 30.23 0.9395 4748 30.23
Gas 221.33 -51.82 -61.28 10 145 0.6503 18.24 1.139 0.03540 178.9 1.139
225 -48.2 -54.7 10 145 0.6321 17.73 1.107 0.03441 173.9 1.107
300 26.9 80.3 10 145 0.4254 11.93 0.7450 0.02316 117.0 0.7450
375 102 215 10 145 0.3296 9.246 0.5772 0.01794 90.68 0.5772
450 177 350 10 145 0.2710 7.602 0.4746 0.01475 74.55 0.4746
Liquid 150 -123 -190 50 725 21.33 598.4 37.36 1.161 5868 37.36
225 -48.2 -54.7 50 725 17.36 487.0 30.40 0.9449 4776 30.40
281.98 8.83 47.89 50 725 9.049 253.9 15.85 0.4926 2489 15.85
Gas 281.98 8.83 47.89 50 725 6.241 175.1 10.93 0.3397 1717 10.93
300 26.9 80.3 50 725 3.128 87.75 5.478 0.1703 860.5 5.478
375 102 215 50 725 1.859 52.15 3.256 0.1012 511.4 3.256
450 177 350 50 725 1.430 40.12 2.504 0.07784 393.4 2.504
Liquid 150 -123.2 -189.7 100 1450 21.46 602.0 37.58 1.168 5904 37.58
225 -48.2 -55 100 1450 17.74 497.7 31.07 0.9656 4880 31.07
Supercritical
phase
300 27 80 100 1450 11.51 322.9 20.16 0.6265 3166 20.16
375 102 215 100 1450 4.358 122.3 7.632 0.2372 1199 7.632
450 177 350 100 1450 3.029 84.97 5.305 0.1649 833.3 5.305
Density units conversion:
Density converter
Densities
Fluid Mechanics
Material Properties
Thermodynamics
Acetone - Density and Specific Weight
Online calculator, figures and tables showing density and specific weight of acetone at temperatures ranging from -95 to 275 °C (-138 to 530 °F) at atmospheric and higher pressure - Imperial and SI Units.
Antifreeze - Ethylene Glycol vs. Propylene Glycol
Comparing ethylene glycol and propylene glycol antifreeze properties.
Online calculator, figures and table showing density and specific weight of benzene, C6H6, at temperatures ranging from 5 to 325 °C (42 to 620 °F) at atmospheric and higher pressure - Imperial and SI Units.
Carbon Monoxide - Density and Specific Weight vs. Temperature and Pressure
Online calculator, figures and tables showing density and specific weight of carbon monoxide, CO, at varying temperature and pressure - Imperial and SI Units.
Density Converter
Ethylene Gas - Specific Heat vs. Temperature
Specific heat of Ethylene Gas - C2H4 - temperatures ranging 175 - 900 K.
Mass vs. Weight
Online calculator, figures and tables showing density and specific weight of methanol,CH3OH, at varying temperature and pressure - Imperial and SI Units.
Nitrogen (N₂) Density & Specific Weight: Temperature & Pressure Data and Calculator
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Pipe Line Velocities vs. Fluid
Typical fluid flow velocities for common liquids, gases and vapors.
Secondary Coolants - Properties
Comparing properties like specific gravity, freezing points and viscosity for secondary coolants like calcium chloride, sodium chloride, ethylene glycol and propylene glycol.
Toluene - Thermophysical Properties
Chemical, physical and thermal properties of toluene, also called methylbenzene, toluol and phenylmethane. Phase diagram included.
