ρ = m / V (1)
γ = m g / V
= ρ g (2)
Tabulated values of ammonia density at given temperature and atmospheric pressure, SI and Imperial units, are given below the figures. /p>
- Density unit converter
Online Ammonia Gas Density Calculator
The calculator below can be used to calculate the ammonia gas density and specific weight at given temperatures and atmospheric pressure.
The output density is given as kg/m3, lb/ft3, lb/gal(US liq) and sl/ft3. Specific weight is given as N/m3and lbf/ ft3.
Note! Temperature must be within the ranges -33 - 425 °C, -28 - 800 °F, 240 - 700 K and 432 - 1260 °R to get valid values.
See also other properties of Ammonia at varying temperature and pressure: Density and specific weight, Dynamic and kinematic viscosity, Prandtl Number, Properties at Gas-Liquid Equilibrium pressure, Specific Heat (Heat Capacity) and Thermal Conductivity, and Thermophysical properties at standard conditions and Vapour pressure at gas-liquid equilibrium,
as well as density and specific weight of acetone, air, argon, benzene, butane, carbon dioxide, carbon monoxide, ethane, ethanol, ethylene, helium, hydrogen, methane, methanol, nitrogen, oxygen, pentane, propane, toluene and water . Density of crude oil , Density of fuel oils , Density of lubricating oil and Density of jet fuel as function of temperature.
Ammonia density and specific weight at 1 bara:
Ammonia gas and liquid density at varying temperature and given pressures:
Ammonia gas density at given temperature (°C) and 1 bara pressure:
For full table with Specific Weight - rotate the screen!
Temperature | Gas Density | Specific weight | ||
(°C) | (g/l), (kg/m3) | (mol/dm3) | (lb/ft3) | (N/m3) |
-35 | 0.8843 | 0.0519 | 0.0552 | 8.672 |
-10 | 0.7938 | 0.0466 | 0.0496 | 7.785 |
0 | 0.7625 | 0.0448 | 0.0476 | 7.478 |
10 | 0.7336 | 0.0431 | 0.0458 | 7.194 |
20 | 0.7069 | 0.0415 | 0.0441 | 6.932 |
30 | 0.6822 | 0.0401 | 0.0426 | 6.690 |
40 | 0.6593 | 0.0387 | 0.0412 | 6.466 |
50 | 0.6380 | 0.0375 | 0.0398 | 6.257 |
75 | 0.5909 | 0.0347 | 0.0369 | 5.795 |
100 | 0.5509 | 0.0323 | 0.0344 | 5.402 |
125 | 0.5162 | 0.0303 | 0.0322 | 5.062 |
150 | 0.4858 | 0.0285 | 0.0303 | 4.764 |
175 | 0.4586 | 0.0269 | 0.0286 | 4.497 |
200 | 0.4341 | 0.0255 | 0.0271 | 4.257 |
250 | 0.3917 | 0.0230 | 0.0245 | 3.842 |
300 | 0.3573 | 0.0210 | 0.0223 | 3.503 |
350 | 0.3295 | 0.0194 | 0.0206 | 3.232 |
400 | 0.3058 | 0.0180 | 0.0191 | 2.999 |
Ammonia gas density at given temperature (°F) and 14.5 psia pressure:
(°F) | (lb/ft3) | (sl/ft3 ×10-3) | (g/l) (kg/m3) | (lbf/ft3) |
-35 | 0.05577 | 1.733 | 0.8933 | 0.0558 |
0 | 0.05119 | 1.591 | 0.8200 | 0.0512 |
20 | 0.04889 | 1.519 | 0.7831 | 0.0489 |
40 | 0.04678 | 1.454 | 0.7494 | 0.0468 |
60 | 0.04486 | 1.394 | 0.7185 | 0.0449 |
80 | 0.04309 | 1.339 | 0.6902 | 0.0431 |
100 | 0.04147 | 1.289 | 0.6642 | 0.0415 |
120 | 0.03997 | 1.242 | 0.6403 | 0.0400 |
150 | 0.03794 | 1.179 | 0.6078 | 0.0379 |
200 | 0.03502 | 1.088 | 0.5610 | 0.0350 |
250 | 0.03254 | 1.012 | 0.5213 | 0.0325 |
300 | 0.03040 | 0.945 | 0.4870 | 0.0304 |
350 | 0.02852 | 0.886 | 0.4569 | 0.0285 |
400 | 0.02684 | 0.834 | 0.4299 | 0.0268 |
500 | 0.02399 | 0.746 | 0.3842 | 0.0240 |
600 | 0.02172 | 0.675 | 0.3480 | 0.0217 |
700 | 0.01993 | 0.620 | 0.3193 | 0.0199 |
800 | 0.01828 | 0.568 | 0.2928 | 0.0183 |
• Air Conditioning Systems
• Air Psychrometrics
• Densities
• Gases and Compressed Air
• Thermodynamics
Acetone - Density and Specific Weight
Online calculator, figures and tables showing density and specific weight of acetone at temperatures ranging from -95 to 275 °C (-138 to 530 °F) at atmospheric and higher pressure - Imperial and SI Units.
Air Properties: Temperature, Pressure & Density Data
Ammonia and health symptoms - smell and threat to life.
Thermodynamic properties of saturated and superheated ammonia R-717 like specific volume, enthalpy and entropy.
Online calculator, figures and table showing density and specific weight of benzene, C6H6, at temperatures ranging from 5 to 325 °C (42 to 620 °F) at atmospheric and higher pressure - Imperial and SI Units.
Density Converter
Mass vs. Weight
Online calculator, figures and tables showing density and specific weight of methanol,CH3OH, at varying temperature and pressure - Imperial and SI Units.
Nitrogen (N₂) Density & Specific Weight: Temperature & Pressure Data and Calculator
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Specific Heat of Common Liquids and Fluids
