Correlations for jet fuel density and temperature are found by use of tools based on ASTM D 1250-04 and IP 200/04 (API Manual of Petroleum Measurement Standards, Chapter 11- physical properties Data, Section 1:Temperature and pressure volume correction factors for generalised crude oils, refined products and lubricating oils). Each colored line represents a jet fuel with a given density at a given temperature. If the temperature changes, the density of the jet fuel changes along the colored line.
Examples of the use of the figures are given below the figures.
If you have the jet fuel density given in °API, use the API-to-gravity converter.
See also similar correlations for fuel oil, crude oil and lubricating oil .
Volume correction factors can be used to calculate the volume of a jet fuel at base temperature (15°C/59°F) if you know the density and volume at another temperature. Or, if you know the base volume and density, you can use the volume correction factor to calculate the volume at another temperature. To be sure you have used the correct figure for correction factors, the easy rule is that the volume increases with increasing temperature.
1.
You have 100 liters of a jet fuel with a density of 757 kg/m3 at 100°C. What is the volume at 15°C?
In the Density vs temperature figure(°C), you se that the yellow line represent this jet fuel.
Then, use the yellow line in the Jet fuel volume correction figure (Density@Observed T/Density@15°C). At 50°C the correction factor is 0.923.
The volume of your jet fuel at 15°C is 100liters*0.923 = 92 liters. (Easy check: Lowest volume at the lowest temperature)
2.
You have 1000 m3 of a jet fuel with a density of 800 kg/m3 at 15°C. How will the volume change if you heat it to 250°C?
In the Density vs temperature figure (°C), you see that the orange line represent this jet fuel.
Then, use the orange line in the Jet fuel volume correction figure (Density@15°C/Density@observed T). At 250°C the correction factor is 1.292.
The volume of your jet fuel at 250°C is 1000m3 *1.292 = 1292 m3. (Easy check: Lowest volume at the lowest temperature)
• Densities
Properties of alternative fuels like biodiesel, E85, CNG and more.
API Gravity: Definition, Calculation, and Converter
API expresses the gravity or density of liquid petroleum products. Online API to Specific Gravity calculator.
Crude Oil Properties - Standard test methods (ASTM and others)
An overview of common test methods and typical ranges of variation of petroleum quality parameters. What, why and how do the different test?
Density Converter
Hydrocarbon Mixtures - Average Boiling Points vs. Gravity and Molecular Weights
Formulas and examples of calculation of boiling point of hydrocarbon mixtures from gravity and molecular weight.
Hydrocarbon Mixtures - Molecular Weight vs. Gravity and Average Boiling Point
Formulas and examples of calculation of average molecular weight of hydrocarbon mixtures from gravity and average boiling point, achieved from distillation data.
Hydrocarbons - Physical Data
Hydrocarbons - Autoignition Temperatures and Flash Points
Autoignition temperatures and flash points (°C and °F) of different types of hydrocarbons with varying carbon numbers up to C12.
Liquid Densities
Liquid-Liquid Solution - Shrinkage and Estimation of Density
It is possible to estimate the density of a liquid-liquid solution from the density of the solute and the solvent. However, due to shrinkage, the estimate will be a bit too low.
Liquids - Specific Gravities
Specific gravities of liquids like alcohol, oils, benzene, water and many more.
Organic Nitrogen Compounds - Physical Data
Boiling and melting points of amines, diamines, pyrroles, pyridines, piperidines and quinolines shown together with their molecular structures, as well as molweights and density.
Organic Sulfur Compounds - Physical Data
Boiling and melting points of thoils, sulfides, disulfides and thiophenes shown together with molecular structures, as well as molweights and density.
Petroleum Products - Average Boiling Points
Definition, explanation and examples of calculation of various types of average boiling point of petroleum products and other mixtures of hydrocarbons: VABP, MABP, WABP, CABP and MeABP.
Petroleum Products - Standard Test Methods (ASTM and others) and Specifications
An overview of common test methods and specifications of petroleum fuels. What, why and how do the different test?
Solids - Densities
Densities of selected solids.
Yield Structure of Crude Oils with Increasing Density of Crude
Yields of different crude oil distillation cuts are plotted as function of whole crude specific gravity. Fractions based on European and North American markets, and the typical differences in crude oil fractionation in the two markets are also shown.
