Liquid-Liquid Solution - Shrinkage and Estimation of Density
Density (mass/volume unit) of solutions where both the solvent and the solute are liquids can be roughly estimated from density of the solute and the solvent by use of the formula:
densitysolution = (x ρsolvent + y ρsolute) / 100 (1)
x = wt% of solvent
ρsolvent = density of solvent
y = wt% of solute
ρsolute = density of solute
However, due to shrinkage, this will only be an estimate , with an error, varying with the concentration of the solute. The error is largest around 50 wt% concentration.
Concentration unit converter
Density of pure organic components: hydrocarbons, carboxylic acids and alcohols, sulphur compounds, nitrogen compounds and other common liquids.
Shrinkage is that the resulting density is higher than calculated by Eq (1), and occurs when molecules with relativele large difference in size are mixed. Then, the smallest molecules are placed in voids between the larger molecules, and the density increases.
The shrinkage will increase with an increasing difference in the molecule size of the solvent and solute. However, also effects other than size, as molecular shape and polarity, will influence on the shrinkage.
Examples showing the effect of shrinkage
At 20°C, the density of water is 0.9982 g/cm3 and the density of pure ethanol is 0.7893 g/cm3. For 20% ethanol, the density can be estimated using Eq (1):
Density20% ethanol = ((80 %) (0.9982 g/cm3) + (20 %) (0.7893 g/cm3)) / (100 %)
= 0.9564 g/cm3
The same calculation is done for 50 and 70 wt% of ethanol, and the results and the difference from measured values are shown in the table below.
Mass% ethanol in water | Density measured | Density estimated | Difference in % |
0 | 0.9982 | ||
20 | 0.9687 | 0.9564 | 1.27 |
50 | 0.9139 | 0.8938 | 2.20 |
70 | 0.8676 | 0.8520 | 1.80 |
100 | 0.7893 |
In the figure below, it is seen that with ethanol concentrations < 20% and > 70%, the estimated values are closer to the measured values.
The figure below shows the shrinkage for aqueous solutions of formic and acetic acids. It illustrates that the shrinkage is largest when the difference in molecular size is largest.
• Densities
Concentration Units Converter
Calculator and formulas for conversion between different units of concentration: Molarity, molality, mole fraction, weight percent of solute and grams of solute per liter of solution - descriptive terms for solubility.
Crude Oil Properties - Standard test methods (ASTM and others)
An overview of common test methods and typical ranges of variation of petroleum quality parameters. What, why and how do the different test?
Ethanol Water Mixtures - Densities vs. Temperature
Density of Ethyl Alcohol aqueous solutions.
Hydrocarbons - Physical Data
Mixtures, Solutions and Suspensions
Mixtures vs. solutions vs. suspensions.
Organic Nitrogen Compounds - Physical Data
Boiling and melting points of amines, diamines, pyrroles, pyridines, piperidines and quinolines shown together with their molecular structures, as well as molweights and density.
Organic Sulfur Compounds - Physical Data
Boiling and melting points of thoils, sulfides, disulfides and thiophenes shown together with molecular structures, as well as molweights and density.
Petroleum Products - Standard Test Methods (ASTM and others) and Specifications
An overview of common test methods and specifications of petroleum fuels. What, why and how do the different test?
