Ethanol Water Mixtures - Densities vs. Temperature
Ethanol Weight (%) | Density (kg/m3) | ||||||
Temperature (oC) | |||||||
10 | 15 | 20 | 25 | 30 | 35 | 40 | |
0 | 1000 | 999 | 998 | 997 | 996 | 994 | 992 |
10 | 984 | 983 | 982 | 980 | 979 | 977 | 975 |
20 | 972 | 971 | 969 | 966 | 964 | 961 | 959 |
30 | 960 | 957 | 954 | 951 | 947 | 944 | 941 |
40 | 942 | 939 | 935 | 931 | 928 | 924 | 920 |
50 | 922 | 918 | 914 | 910 | 906 | 902 | 897 |
60 | 899 | 895 | 891 | 887 | 883 | 878 | 874 |
70 | 876 | 872 | 868 | 863 | 859 | 855 | 850 |
80 | 852 | 848 | 843 | 839 | 835 | 830 | 826 |
90 | 827 | 822 | 818 | 814 | 809 | 805 | 800 |
100 | 798 | 794 | 789 | 785 | 781 | 776 | 772 |
The composition is mass ethanol per mass of solution.
Ethanol - Thermophysical properties
Chemical, physical and thermal properties of ethanol (also called alcohol or ethyl alcohol). Phase diagram included.
Ethanol Freeze Protected Water Solutions
Freezing temperature and flash points for ethanol based water solutions or brines.
Freezing Mixtures and Cooling Agents
Freezing mixtures, cooling agents and freezing points.
Liquid Densities
Liquid-Liquid Solution - Shrinkage and Estimation of Density
It is possible to estimate the density of a liquid-liquid solution from the density of the solute and the solvent. However, due to shrinkage, the estimate will be a bit too low.
Methanol Freeze Protected Heat Transfer Liquids
Freezing and flash points for methanol or methyl based heat-transfer fluids or brines.
