Ethanol Freeze Protected Water Solutions
Ethanol based Water Solutions Freezing Point
| Ethanol Concentration (% by volume) | 0 | 10 | 20 | 30 | 40 | 50 | 60 | 70 | 80 | 90 | 100 | |
| Freezing Point | (oF) | 32 | 25 | 15 | 5 | -10 | -25 | -35 | -55 | -75 | -110 | -175 |
| (oC) | 0 | -4 | -9 | -15 | -23 | -32 | -37 | -48 | -59 | -73 | -115 | |
Flash Points of Ethanol based Water Solutions
The flash point of a chemical is the lowest temperature where it will evaporate enough fluid to form a combustible concentration of gas. The flash point is an indication of how easy a chemical may burn.
| Ethanol Concentration (% by weight) | 5 | 10 | 20 | 30 | 40 | 50 | 60 | 70 | 80 | 90 | 96 | |
| Flash Point | (oF) | 144 | 120 | 97 | 84 | 79 | 75 | 72 | 70 | 68 | 63 | 55 |
| (oC) | 62 | 49 | 36 | 29 | 26 | 24 | 22 | 21 | 20 | 17 | 13 | |
Warning
- HIGH flammability if pure
Download and print Ethanol Water Solution - Freezing Temperature and Flash Point chart.
Alternatives to Ethanol based Water Solutions
- Ethylene glycol based water solutions
- Propylene glycol based water solutions
- Methanol based water solutions
Example - Ethanol Concentration at Freezing Point at -20 oC
By using linear interpolation between two known concentrations and their freezing points - the concentration at a third freezing point can be calculated as
CC = ((CB - CA) / (tB - tA)) (tC - tA) + CA (1)
C = concentration in ethanol - water solution
t = freezing point (oC, oF)
A, B = known freezing points
C = calculated freezing point
The ethanol concentration with freezing point at -20 oC can be calculated by interpolating the concentration between freezing point -15 oC and -23 oC in the table above.
Cc = (((40 %) - (30 %)) / ((-23 oC) - (-15 oC))) ((-20 oC) - (-15 oC)) + (30 %) = 36.25 %
Note that this calculation is simplified by assuming that the concentration vs. freezing point follows a straight line. This not necessary correct.
If a 90% ethanol-water solution shall be mixed with clean water to achieve a freezing point of -20 oC (ethanol concentration 36.25% (0.3625)) - the amount of added water can be calculated with volume balance - the amount of ethanol before mix is the same as after the mix:
C Vs = Cm (Vs + Vw) (2)
Vs = volume of the ethanol - water solution (liter, gallon)
Cm = concentration in mix
Vm = volume of mix (liter, gallon)
Vw = volume of the added clean water (liter, gallon)
Rearranging the equation to express the volume of water added to the mixture
Vw = (C - Cm) Vs / Cm (2b)
Substituting with values
Vw = (0.9 - 0.3625) Vs / 0.3625
= 1.48 Vs
- for every liter 90% ethanol-water solution 1.48 liter of clean water must be mixed in to achieve an ethanol concentration of 36.25 % and freezing point -20 oC.
• Melting and Freezing Points
Calcium Chloride Water Solutions
Freezing point, density, specific heat and dynamic viscosity of Calcium Chloride Water coolants.
Ethanol Water Mixtures - Densities vs. Temperature
Density of Ethyl Alcohol aqueous solutions.
Freeze Protection of Water based Heat Transfer Fluids
Comparing antifreezes used in water based heat transfer fluids or brines.
Freezing Mixtures and Cooling Agents
Freezing mixtures, cooling agents and freezing points.
Hazard vs. Flash Points
The flash point of a chemical indicates how easy it may ignite and burn.
Isopropanol (2-Propanol) based Freeze Protected Water Solutions
Freezing and flash points of isopropanol (2-Propanol) based water solutions or brines.
Liquids - Freezing and Melting Points
Common fluids and their freezing and melting points.
Methanol Freeze Protected Heat Transfer Liquids
Freezing and flash points for methanol or methyl based heat-transfer fluids or brines.
Sodium Chloride Water Solutions
Freezing point, density, specific heat and dynamic viscosity of Sodium Chloride and Water coolant.
