The flash point of a chemical is the lowest temperature where it will evaporate enough fluid to form a combustible concentration of gas. The flash point is an indication of how easy a chemical may burn.
Isopropanol Concentration (% by volume) | 0 | 10 | 20 | 30 | 40 | 50 | 60 | 70 | 80 | 90 | 100 | |
Flash Points | oF | - | 105 | 85 | 75 | 70 | 65 | 65 | 65 | 65 | 65 | 53 |
oC | - | 41 | 29 | 24 | 21 | 18 | 18 | 18 | 18 | 18 | 12 |
Freeze protecting of cooling systems - temperature rating vs. required amount of antifreeze.
Freezing point, density, specific heat and dynamic viscosity of Calcium Chloride Water coolants.
Freezing temperature and flash points for ethanol based water solutions or brines.
Comparing antifreezes used in water based heat transfer fluids or brines.
Freezing mixtures, cooling agents and freezing points.
Boiling and freezing points of glycerine aqueous solutions.
The flash point of a chemical indicates how easy it may ignite and burn.
Freezing and flash points for methanol or methyl based heat-transfer fluids or brines.
Comparing properties like specific gravity, freezing points and viscosity for secondary coolants like calcium chloride, sodium chloride, ethylene glycol and propylene glycol.
