Antifreeze - Ethylene Glycol Volume vs. Temperature Rating
Required amount of antifreeze to protect cooling systems at specific temperature ratings can be estimated from the charts below:
  • tC = 0.56 (tF - 32) = 5/9 (tF - 32)
  • 1 Gallon (U.S.) = 3.785×10-3 m3 = 3.785 dm3 (liter) = 231 in3 = 0.13368 ft3 = 4.951×10-3 yd3 = 0.8327 Imp. gal (UK) = 4 Quarts = 8 Pints
Never use more than 70% antifreeze in a cooling system.
Air Conditioning Systems
Material Properties
Miscellaneous
Antifreeze - Ethylene Glycol vs. Propylene Glycol
Comparing ethylene glycol and propylene glycol antifreeze properties.
Calcium Chloride Water Solutions
Freezing point, density, specific heat and dynamic viscosity of Calcium Chloride Water coolants.
Freeze Protection of Water based Heat Transfer Fluids
Comparing antifreezes used in water based heat transfer fluids or brines.
Isopropanol (2-Propanol) based Freeze Protected Water Solutions
Freezing and flash points of isopropanol (2-Propanol) based water solutions or brines.
Liquids - Volumetric Expansion Coefficients
Volumetric - or cubical - expansion coefficients for common liquids.
Methanol Freeze Protected Heat Transfer Liquids
Freezing and flash points for methanol or methyl based heat-transfer fluids or brines.
Secondary Coolants - Properties
Comparing properties like specific gravity, freezing points and viscosity for secondary coolants like calcium chloride, sodium chloride, ethylene glycol and propylene glycol.
Snow Melting Systems
Sizing snow melting systems - water and antifreeze.
