Note the eutectic point at 29.92 % as indicated in the chart above.
Freeze protecting of cooling systems - temperature rating vs. required amount of antifreeze.
Freezing temperature and flash points for ethanol based water solutions or brines.
Comparing antifreezes used in water based heat transfer fluids or brines.
Freezing and flash points of isopropanol (2-Propanol) based water solutions or brines.
Comparing properties like specific gravity, freezing points and viscosity for secondary coolants like calcium chloride, sodium chloride, ethylene glycol and propylene glycol.
Freezing point, density, specific heat and dynamic viscosity of Sodium Chloride and Water coolant.
