Freeze Protection of Water based Heat Transfer Fluids
Different types and concentrations of antifreezes like
- ethanol
- methanol
- propylene glycol
- ethylene glycol
can be used to freeze protect water based heat transfer fluids or brines where the temperature in the fluid is below 0 oC (31 oF). Typical advantages and disadvantages for the freeze protection fluids are listed below.
Note! Check the related documents listed below for details.
Ethanol
- low corrosiveness
- high flammability (if pure)
- low toxicity
- high heat transfer capacity
- low pumping requirements due to viscosity
- moderate cost
Methanol
- low corrosiveness
- high toxicity
- low cost
Propylene Glycol
- low corrosiveness
- low flammability
- low toxicity
- low heat transfer capacity
- high pumping requirements due to viscosity
- high cost
Ethylene Glycol
- low corrosiveness
- low flammability
- high toxicity
- high cost
• Air Conditioning Systems
Antifreeze - Ethylene Glycol Volume vs. Temperature Rating
Freeze protecting of cooling systems - temperature rating vs. required amount of antifreeze.
Antifreeze - Ethylene Glycol vs. Propylene Glycol
Comparing ethylene glycol and propylene glycol antifreeze properties.
Calcium Chloride Water Solutions
Freezing point, density, specific heat and dynamic viscosity of Calcium Chloride Water coolants.
Ethanol Freeze Protected Water Solutions
Freezing temperature and flash points for ethanol based water solutions or brines.
Isopropanol (2-Propanol) based Freeze Protected Water Solutions
Freezing and flash points of isopropanol (2-Propanol) based water solutions or brines.
Methanol - Thermophysical Properties vs. Temperature
Thermophysical properties of methanol.
Methanol Freeze Protected Heat Transfer Liquids
Freezing and flash points for methanol or methyl based heat-transfer fluids or brines.
Sodium Chloride Water Solutions
Freezing point, density, specific heat and dynamic viscosity of Sodium Chloride and Water coolant.
