Methanol - Thermophysical Properties vs. Temperature
Methanol (methyl alcohol, carbinol, wood alcohol, wood naptha or wood spirits) is a chemical compound with chemical formula CH3OH. Thermophysical properties for temperatures ranging -50-150 oC are indicated in the table below.
For full table with Liquid Viscosity, Vapor Viscosity, Vapor Pressure, Vapor Specific Heat and Liquid Surface Tension - rotate the screen!
Temperature (oC) | Latent Heat (kJ/kg) | Liquid Density (kg/m3) | Vapor Density (kg/m3) | Liquid Thermal Conductivity (W/moC) | Liquid Viscosity (cP) | Vapor Viscosity (102 cP) | Vapor Pressure (bar) | Vapor Specific Heat (kJ/kgoC) | Liquid Surface Tension (10-2 N/m) |
-50 | 1194 | 844 | 0.01 | 0.210 | 1.700 | 0.72 | 0.01 | 1.20 | 3.26 |
-30 | 1187 | 834 | 0.01 | 0.208 | 1.300 | 0.78 | 0.02 | 1.27 | 2.95 |
-10 | 1182 | 819 | 0.04 | 0.206 | 0.945 | 0.85 | 0.04 | 1.34 | 2.63 |
10 | 1175 | 801 | 0.12 | 0.204 | 0.701 | 0.91 | 0.10 | 1.40 | 2.36 |
30 | 1155 | 782 | 0.31 | 0.203 | 0.521 | 0.98 | 0.25 | 1.47 | 2.18 |
50 | 1125 | 764 | 0.77 | 0.202 | 0.399 | 1.04 | 0.55 | 1.54 | 2.01 |
70 | 1085 | 746 | 1.47 | 0.201 | 0.314 | 1.11 | 1.31 | 1.61 | 1.85 |
90 | 1035 | 724 | 3.01 | 0.199 | 0.259 | 1.19 | 2.69 | 1.79 | 1.66 |
110 | 980 | 704 | 5.64 | 0.197 | 0.211 | 1.26 | 4.98 | 1.92 | 1.46 |
130 | 920 | 685 | 9.81 | 0.195 | 0.166 | 1.31 | 7.86 | 1.92 | 1.25 |
150 | 850 | 653 | 15.9 | 0.193 | 0.138 | 1.38 | 8.94 | 1.92 | 1.04 |
Freeze Protection of Water based Heat Transfer Fluids
Comparing antifreezes used in water based heat transfer fluids or brines.
Higher Calorific Values of Common Fuels: Reference & Data
Higher and lower calorific values (heating values) for fuels like coke, oil, wood, hydrogen and others.
Liquid Densities
Liquids - Latent Heat of Evaporation
Latent heat of vaporization for fluids like alcohol, ether, nitrogen, water and more.
Liquids - Specific Gravities
Specific gravities of liquids like alcohol, oils, benzene, water and many more.
Liquids - Volumetric Expansion Coefficients
Volumetric - or cubical - expansion coefficients for common liquids.
Methanol Freeze Protected Heat Transfer Liquids
Freezing and flash points for methanol or methyl based heat-transfer fluids or brines.
