Liquids - Volumetric Expansion Coefficients
Volumetric thermal expansion coefficients for some common liquids are indicated below.
LiquidVolumetric Coefficient of Expansion
(1/K, 1/oC)
Acetic acid 0.00110
Acetone 0.00143
Alcohol, ethyl (ethanol) 0.00109
Alcohol, methyl (methanol,wood alcohol, wood naphtha, wood spirits, CH3OH) 0.00149
Ammonia 0.00245
Aniline 0.00085
Benzene 0.00125
Bromine 0.00110
Calcium Chloride, 5.8% solution 0.00025
Calcium Chloride, 40.9% solution 0.00046
Carbon disulfide 0.00119
Carbon tetrachloride 0.00122
Chloroform 0.00127
Engine oil 0.0007
Ether 0.00160
Ethyl acetate 0.00138
Ethylene glycol 0.00057
Dichlorodifluoromethane refrigerant R-12 0.0026
n-Heptane 0.00124
Hydrochloric acid, 33.2% solution 0.00046
Hydrogen (liquid 20.3 K) 0.0151
Isobutyl alcohol 0.00094
Gasoline 0.00095
Glycerine (glycerol) 0.00050
Kerosene, jet fuel 0.00099
Mercury 0.00018
Methyl iodide 0.0012
Nitrogen (liquid 100 K) 0.009
n-Octane 0.00114
Oil (unused engine oil) 0.00070
Olive oil 0.00070
Oxygen (liquid 89 K) 0.002
Paraffin oil 0.000764
Petroleum 0.0010
n-Pentane 0.00158
Phenol 0.0009
Potassium chloride, 24.3% solutiuon 0.00035
Sodium 0.00027
Sodium chloride, 20.6% solution 0.00041
Sodium sulfate, 24% solution 0.00041
Sulfuric acid, concentrated 0.00055
Toluene 0.00108
Trichloroethylene 0.001170
Turpentine 0.001000
Water at aprox. 20 oC (68 oF)  1)
0.000214
1) Volumetric expansion coefficient for water varies with temperature
Thermodynamics
Antifreeze - Ethylene Glycol Volume vs. Temperature Rating
Freeze protecting of cooling systems - temperature rating vs. required amount of antifreeze.
Linear Thermal Expansion Coefficients of Materials
Linear thermal expansion coefficients of common materials, including metals, plastics, and composites.
Methanol - Thermophysical Properties vs. Temperature
Thermophysical properties of methanol.
Shrink-Fits Assembly
Assembly temperatures for shrink-fits.
Solids - Volume Temperature Expansion Coefficients
Cubical expansion coefficients for solids.
Thermal Expansion - Superficial i.e. Area
Superficial i.e area temperature expansion - online calculator.
Toluene Liquid - Thermal Properties vs. Temperature
Density, specific heat, thermal conductivity and more.
