Solids - Volume Temperature Expansion Coefficients
| Solid | Expansion Coefficient (10-6 1/K) |
| Aluminum | 69 |
| Antimony | 31.7 |
| Beryl | 1.1 |
| Bismuth | 39.5 |
| Brass | 57 |
| Carbon steel | 32.4 |
| Concrete | 36 |
| Copper | 49.9 |
| Diamond | 3.5 |
| Douglas-fir | 75 |
| Emerald | 1.7 |
| Galena | 55.8 |
| Glass | 27.6 |
| Glass, borosilicate | 9.9 |
| Gold | 44.1 |
| Ice | 112.5 |
| Iron | 35.5 |
| Lead | 84 |
| Magnesium | 78 |
| Molybdenum | 14.4 |
| Nickel | 39 |
| Paraffin | 590 |
| Platinum | 26.5 |
| Polypropylene, PP | 450 |
| Porcelain | 8.1 |
| PVC | 156 |
| Quartz | 38.4 |
| Rock salt | 121.2 |
| Rubber | 487 |
| Silicon | 9 |
| Silicon Carbide | 8.3 |
| Silver | 58.3 |
| Sodium | 213 |
| Stainless Steel | 30 - 52 |
| Stearic acid | 810 |
| Steel | 33 - 39 |
| Sulfur | 223 |
| Tin | 69 |
| Titanium | 26 |
| Tungsten | 13.5 |
| Zinc | 89.3 |
• Thermodynamics
Linear Thermal Expansion Coefficients of Materials
Linear thermal expansion coefficients of common materials, including metals, plastics, and composites.
Linear Thermal Expansion: Formula, Coefficients & Calculator
Liquids - Volumetric Expansion Coefficients
Volumetric - or cubical - expansion coefficients for common liquids.
Shrink-Fits Assembly
Assembly temperatures for shrink-fits.
