Shrink-Fits Assembly
Shrink-fits are assembled by heating them to temperatures where the expansion exceeds the interference. Required heating temperature can be calculated as
dt = δ / α di (1)
dt = temperature heating (oC, oF)
δ = diametric interference (mm, in)
α = coefficient of linear expansion (m/moK, in/inoF)
di = initial diameter of hole before expansion (mm, in)
Diametric interference can be calculated as
δ = dt α di (2)
Linear Thermal Expansion Coefficients of Materials
Linear thermal expansion coefficients of common materials, including metals, plastics, and composites.
Linear Thermal Expansion: Formula, Coefficients & Calculator
Liquids - Volumetric Expansion Coefficients
Volumetric - or cubical - expansion coefficients for common liquids.
Solids - Volume Temperature Expansion Coefficients
Cubical expansion coefficients for solids.
