Linear temperature expansion copper tubes, stainless steel pipes, carbon steel pipes, ductile iron pipes and aluminum tubes are indicated below.
Temperature Change (oF) | Linear Temperature Expansion (in/100 ft) | ||||
Copper | Stainless Steel | Carbon Steel | Ductile Iron | Aluminum | |
0 | 0.0 | 0.0 | 0.0 | 0.0 | 0.0 |
10 | 0.1 | 0.1 | 0.1 | 0.1 | 0.2 |
20 | 0.2 | 0.2 | 0.2 | 0.2 | 0.3 |
40 | 0.5 | 0.5 | 0.4 | 0.4 | 0.6 |
50 | 0.6 | 0.6 | 0.5 | 0.5 | 0.8 |
60 | 0.7 | 0.7 | 0.6 | 0.5 | 1.0 |
70 | 0.8 | 0.8 | 0.7 | 0.6 | 1.1 |
80 | 0.9 | 0.9 | 0.7 | 0.7 | 1.3 |
90 | 1.1 | 1.0 | 0.8 | 0.8 | 1.4 |
100 | 1.2 | 1.1 | 0.9 | 0.9 | 1.6 |
120 | 1.4 | 1.4 | 1.1 | 1.1 | 1.9 |
140 | 1.6 | 1.6 | 1.3 | 1.3 | 2.2 |
160 | 1.9 | 1.8 | 1.5 | 1.4 | 2.5 |
180 | 2.1 | 2.0 | 1.7 | 1.6 | 2.9 |
200 | 2.4 | 2.3 | 1.9 | 1.8 | 3.2 |
220 | 2.6 | 2.5 | 2.1 | 2.0 | 3.5 |
240 | 2.8 | 2.7 | 2.2 | 2.2 | 3.8 |
260 | 3.1 | 2.9 | 2.4 | 2.3 | 4.1 |
280 | 3.3 | 3.2 | 2.6 | 2.5 | 4.4 |
300 | 3.5 | 3.4 | 2.8 | 2.7 | 4.8 |
320 | 3.8 | 3.6 | 3.0 | 2.9 | 5.1 |
340 | 4.0 | 3.8 | 3.2 | 3.1 | 5.4 |
360 | 4.2 | 4.1 | 3.4 | 3.2 | 5.7 |
380 | 4.5 | 4.3 | 3.6 | 3.4 | 6.0 |
400 | 4.7 | 4.5 | 3.7 | 3.6 | 6.3 |
- ΔT(oC) = 5/9 ΔT(oF)
- 1 ft (foot) = 0.3048 m
- 1 in (inch) = 25.4 mm
Example - Temperature Expansion of Copper Tube
A copper tube with length 35 m (115 ft) is heated from 20 oC (68 oF) to 60 oC (140 oF) - a temperature difference of 40 oC (71 oF). The linear expansion from the table above is approximately 0.13 m/100m (1.6 in/100ft).
The expansion of the tube can be calculated
dl = (35 m) (0.13 m/100 m) / (100 m)
= 0.05 m
Alternatively in Imperial units:
dl = (115 ft) (1.6 in/100 ft) / (100 ft)
= 1.8 in
• Temperature Expansion
ASTM B302 - Threadless Copper Pipes - Dimensions
ASTM B42 - Seamless Copper Pipes - Dimensions
ASTM B43 - Seamless Red Brass Pipes - Dimensions
Standard sizes specification for seamless red brass pipes.
ASTM B837 - Seamless Copper Tubes for Natural Gas and Liquified Petroleum - Dimensions
Copper - Density, Specific Heat and Thermal Conductivity vs. Temperature
Density, specific heat and thermal conductivity of copper vs. temperature
Copper Tubes - Expansion Loop Capacity
Capacity of copper tubes expansion loops.
Copper Tubes - Pressure Loss vs. Water Flow
Water flow and pressure loss (psi/ft) due to friction in copper tubes ASTM B88 Types K, L and M.
EN 10312 - Welded Stainless Steel Tubes for the Conveyance of Aqueous Liquids Including Water for Human Consumption - Dimensions
Dimensions of welded stainless steel tubes according EN 10312.
Iron - Density, Specific Heats and Thermal Conductivities vs. Temperatures
Specific heat, density and thermal conductivity of iron related to temperature.
Linear Thermal Expansion Coefficients of Materials
Linear thermal expansion coefficients of common materials, including metals, plastics, and composites.
Linear Thermal Expansion: Formula, Coefficients & Calculator
Piping Materials - Temperature Heat Expansion and Cooling Contraction
Expansion and contraction when cast iron, carbon and carbon molybdenum steel, wrought iron, copper, brass and aluminum pipes are heated or cooled.
Shrink-Fits Assembly
Assembly temperatures for shrink-fits.
Stainless Steel - Comparing International Standards
Comparing international stainless steel standards from America (US), France, Germany, Italy, Japan, Russia, Spain, Sweden, England (UK) and the European Union.
Stainless Steel Classifications
Stainless steels are commonly grouped into martensitic stainless steels, ferritic stainless steels, austenitic stainless steels, duplex (ferritic-austenitic) stainless steels, and precipitation-hardening stainless steels.
Stainless Steel Pipes - American vs. European Standards
American - US - vs. European - German, British (UK) and Swedish - stainless steel pipe standards.
Stainless Steels - Identification Tests
Magnetic, spark, hardness and acid identification tests for austenitic, martensitic and ferritic stainless steels.
Steel Pipes Expansion Loops - Design and Calculation
Steel pipe expansion loops and their importance in managing thermal expansion, and how to design and size them effectively. Key considerations, calculations, and installation tips to prevent stress and damage in piping systems.
