Stainless Steels - Identification Tests
Stainless steels can be hard to identify. The different types can be distinguished by methods as
  • magnet testing
  • spark testing
  • hardness testing
  • acid testing
For full table with Sulfuric and Hydrochloric Acid Test - rotate the screen!
AISI TypeGradeGroupMagnet TestSpark TestHardness TestSulfuric Acid TestHydrochloric Acid Test
302 Chromium-
Nickel
Austenitic Non-
Magnetic
Few forks - short, reddish >165 Brinell after heated to 1800 oF and water quench Strong attack - green crystals and dark surface Rapid reaction - pale blue-green solution
303 Spoiled egg odor - heavy black smudge
303Se Garlic odor
304 Strong attack - green crystals and dark surface Fast attack - gas formation
308 Full red without many forks
309
310
316 Few forks - short, reddish Slow attack - tan surface turns brown Very slow attack
317
321 Fast attack - gas formation
347
410 Chromium Martensitic Magnetic Long white with few forks > 280 Brinell after heated to 1800 oF and water quench Rapid reaction - dark green solution
414
416 Spoiled egg odor - heavy black smudge
416Se Garlic odor
420 Long white-red with burst
431 Long white with few forks
440 A, B, C Long white-red with burst
430 Ferritic Long white with few forks 180 - 250 Brinell after heated to 1800 oF and water quench
430F Spoiled egg odor - heavy black smudge
430FSe Garlic odor
446 Full red without many forks
Corrosion
Dimensions of Pipes and Tubes
Material Properties
AISI 310 Stainless Steel - Properties
Thermal diffusivity, specific heat capacity, density and thermal conductivity of stainless steel AISI 310 vs. temperature.
ASME/ANSI B36.10/19 - Carbon, Alloy and Stainless Steel Pipe - Dimensions
ASTM A312 Stainless Steel Pipes - Bursting and Collapsing Pressures
Theoretic bursting and collapsing pressures for stainless steel pipes ASTM A312.
Brinell Hardness Number - BHN
The Brinell hardness test of metals and alloys.
Composition of Steels
Typical composition of AISI steels.
Malleability vs. Brittlenes vs. Ductility
Plastic deformation properties.
Metals - Machinability
The machinability of some common metals.
NDT - Non Destructive Testing
Non-destructive construction testing.
Piping Materials - Galvanic Corrosion
Connecting pipes of different materials may cause galvanic corrosion and serious damage.
Stainless Steel - Comparing International Standards
Comparing international stainless steel standards from America (US), France, Germany, Italy, Japan, Russia, Spain, Sweden, England (UK) and the European Union.
Stainless Steel Classifications
Stainless steels are commonly grouped into martensitic stainless steels, ferritic stainless steels, austenitic stainless steels, duplex (ferritic-austenitic) stainless steels, and precipitation-hardening stainless steels.
Stainless Steel Pipes - Allowable Pressure vs. Schedule and Size
Allowable pressure for standard seamless A312-TP316/316L stainless steel pipes - temperatures 100oF to 750oF.
Stainless Steel Pipes - American vs. European Standards
American - US - vs. European - German, British (UK) and Swedish - stainless steel pipe standards.
Stainless Steel Weld Fittings - ANSI/ASME B36.19
Dimensions of stainless steel weld fittings according ANSI/ASME B36.19.
Stainless Steels - Corrosion Resistance
Corrosion resistanse of AISI stainless steels in various environments.
Steel Tempering Colors
The tempering process of hardening steel.
