AISI 310 Stainless Steel - Properties
Stainless steel AISI 310 - thermal diffusivity, specific heat capacity, density and thermal conductivity vs temperature:
Thermal diffusivity
Specific heat capacity
Density
Thermal conductivity
Temperature
(°C)
Thermal Conductivity
(W/mK)
-125 9.4
-100 10.1
-75 10.8
-50 11.2
-25 11.7
0 12.1
25 12.7
50 13.2
100 14.1
150 15.0
200 15.8
250 16.6
300 17.3
350 18.0
400 18.8
450 19.4
500 20.1
550 20.9
600 22.2
650 23.0
700 23.7
750 24.0
800 24.5
850 25.2
900 26.0
950 26.9
1000 27.7
Material Properties
ASME/ANSI B36.10/19 - Carbon, Alloy and Stainless Steel Pipes - Dimensions
ASTM Cross Reference Material Specifications
Cross reference for fittings, flanges, unions and cast and foged valves.
Stainless Steel - Comparing International Standards
Comparing international stainless steel standards from America (US), France, Germany, Italy, Japan, Russia, Spain, Sweden, England (UK) and the European Union.
Stainless Steel - Specific Heat and Thermal Conductivities vs. Temperatures
Specific heat and thermal conductivity of stainless steel vs. temperature
Stainless Steel Classifications
Stainless steels are commonly grouped into martensitic stainless steels, ferritic stainless steels, austenitic stainless steels, duplex (ferritic-austenitic) stainless steels, and precipitation-hardening stainless steels.
Stainless Steel Pipes - American vs. European Standards
American - US - vs. European - German, British (UK) and Swedish - stainless steel pipe standards.
Stainless Steels - Corrosion Resistance
Corrosion resistanse of AISI stainless steels in various environments.
Stainless Steels - Identification Tests
Magnetic, spark, hardness and acid identification tests for austenitic, martensitic and ferritic stainless steels.
UNS - Unified Numbering System
The Unified Numbering System - UNS - used for metals and alloys.
