(K)
Thermal diffusivity, specific heat capacity, density and thermal conductivity of stainless steel AISI 310 vs. temperature.
Dimensions of ASTM A270 sanitary steel tubes.
Theoretic bursting and collapsing pressures for stainless steel pipes ASTM A312.
Dimensions of welded stainless steel tubes according EN 10312.
Thermal conductivities of common metals, metallic elements aand alloys.
Comparing international stainless steel standards from America (US), France, Germany, Italy, Japan, Russia, Spain, Sweden, England (UK) and the European Union.
Allowable pressure for standard seamless A312-TP316/316L stainless steel pipes - temperatures 100oF to 750oF.
Dimensions of stainless steel weld fittings according ANSI/ASME B36.19.
