ASTM A270 Sanitary Stainless Steel Tubing - Dimensions
Outside Diameter | Nominal Wall Thickness | Weight | ||
(in) | (mm) | (in) | (mm) | (kg/m) |
1/2 | 12.7 | 0.065 | 1.65 | 0.454 |
3/4 | 19.1 | 0.065 | 1.65 | 0.717 |
1 | 25.4 | 0.065 | 1.65 | 0.976 |
1 1/2 | 38.1 | 0.065 | 1.65 | 1.50 |
2 | 50.8 | 0.065 | 1.65 | 2.02 |
2 1/2 | 63.5 | 0.065 | 1.65 | 2.54 |
3 | 76.2 | 0.065 | 1.65 | 3.06 |
4 | 101.6 | 0.083 | 2.11 | 5.23 |
6 | 152.4 | 0.109 | 2.77 | 10.32 |
8 | 203.2 | 0.109 | 2.77 |
ASTM International - Standards for Steel Pipes, Tubes and Fittings
The ASTM standards covers various types of steel pipes, tubes and fittings for high-temperature services, ordinary use and special applications such as fire protection use
ASTM International - Volume 01.01 Steel - Piping, Tubing, Fittings
An overview of the ASTM Volume 01.01 standard.
Process Pipes - Allowable Stress vs. Temperature
Allowable wall stress in pipes according ASME M31.3.
Stainless Steel - Specific Heat and Thermal Conductivities vs. Temperatures
Specific heat and thermal conductivity of stainless steel vs. temperature
Steel Pipes Expansion Loops - Design and Calculation
Steel pipe expansion loops and their importance in managing thermal expansion, and how to design and size them effectively. Key considerations, calculations, and installation tips to prevent stress and damage in piping systems.
