ASTM International - Standards for Steel Pipes, Tubes and Fittings
The ASTM International specifications for steel tubes list standard requirements for boiler and super heater tubes, general service tubes, steel tubes in refinery service, heat exchanger and condenser tubes, mechanical and structural tubing.
Steel Pipes
- A53 - A53/A53M-99b - Specification for Pipe, Steel, Black and Hot-Dipped, Zinc-Coated, Welded and Seamless
- A74 - A74-98 - Specification for Cast Iron Soil Pipe and Fittings
- A106 - A106-99e1 - Specification for Seamless Carbon Steel Pipe for High-Temperature Service
- A126 - A126-95e1 - Specification for Grey Iron Castings for Valves, Flanges, and Pipe Fittings
- A134 - A134-96 - Specification for Pipe, Steel, Electric-Fusion (Arc)-Welded (Sizes NPS 16 and Over)
- A135 - A135-97c - Specification for Electric-Resistance-Welded Steel Pipe
- A139 - A139-96e1 - Specification for Electric-Fusion (Arc)-Welded Steel Pipe (NPS 4 and Over)
- A182 - A182/A182M-99 - Specification for Forged or Rolled Alloy-Steel Pipe Flanges, Forged Fittings, and Valves and Parts for High-Temperature Service
- A252 - A252-98 - Specification for Welded and Seamless Steel Pipe Piles
- A312 - A312/A312M-00 - Specification for Seamless and Welded Austenitic Stainless Steel Pipes
- A333 - A333/A333M-99 - Specification for Seamless and Welded Steel Pipe for Low-Temperature Service
- A335 - A335/A335M-99 - Specification for Seamless Ferritic Alloy-Steel Pipe for High-Temperature Service
- A338 - A338-84 (1998) - Specification for Malleable Iron Flanges, Pipe Fittings, and Valve Parts for Railroad, Marine, and Other Heavy Duty Service at Temperatures Up to 650 oF (345 oC)
- A358 - A358/A358M-98 - Specification for Electric-Fusion-Welded Austenitic Chromium-Nickel Alloy Steel Pipe for High-Temperature Service
- A369 - A369/A369M-92 - Specification for Carbon and Ferritic Alloy Steel Forged and Bored Pipe for High-Temperature Service
- A376 - A376/A376M-98 - Specification for Seamless Austenitic Steel Pipe for High-Temperature Central-Station Service
- A377 - A377-99 - Index of Specifications for Ductile-Iron Pressure Pipe
- A409 - A409/A409M-95ae1 - Specification for Welded Large Diameter Austenitic Steel Pipe for Corrosive or High-Temperature Service
- A426 - A426-92 (1997) - Specification for Centrifugally Cast Ferritic Alloy Steel Pipe for High-Temperature Service
- A451 - A451-93 (1997) - Specification for Centrifugally Cast Austenitic Steel Pipe for High-Temperature Service
- A523 - A523-96 - Specification for Plain End Seamless and Electric-Resistance-Welded Steel Pipe for High-Pressure Pipe-Type Cable Circuits
- A524 - A524-96 - Specification for Seamless Carbon Steel Pipe for Atmospheric and Lower Temperatures
- A530 - A530/A530M-99 - Specification for General Requirements for Specialized Carbon and Alloy Steel Pipe
- A648 - A648-95e1 - Specification for Steel Wire, Hard Drawn for Pre-stressing Concrete Pipe
- A674 - A674-95 - Practice for Polyethylene Encasement for Ductile Iron Pipe for Water or Other Liquids
- A691 - A691-98 - Specification for Carbon and Alloy Steel Pipe, Electric-Fusion-Welded for High-Pressure Service at High Temperatures
- A694 - A694/A694M-00 - Specification for Carbon and Alloy Steel Forgings for Pipe Flanges, Fittings, Valves, and Parts for High-Pressure Transmission Service
- A716 - A716-99 - Specification for Ductile Iron Culvert Pipe
- A733 - A733-99 - Specification for Welded and Seamless Carbon Steel and Austenitic Stainless Steel Pipe Nipples
- A742 - A742/A742M-98 - Specification for Steel Sheet, Metallic Coated and Polymer Pre-coated for Corrugated Steel Pipe
- A746 - A746-99 - Specification for Ductile Iron Gravity Sewer Pipe
- A760 - A760/A760M-99 - Specification for Corrugated Steel Pipe, Metallic-Coated for Sewers and Drains
- A761 - A761/A761M-98 - Specification for Corrugated Steel Structural Plate, Zinc-Coated, for Field-Bolted Pipe, Pipe-Arches, and Arches
- A762 - A762/A762M-98 - Specification for Corrugated Steel Pipe, Polymer Pre-coated for Sewers and Drains
- A790 - A790/A790M-99 - Specification for Seamless and Welded Ferritic/Austenitic Stainless Steel Pipe
- A796 - A796/A796M-99 - Practice for Structural Design of Corrugated Steel Pipe, Pipe-Arches, and Arches for Storm and Sanitary Sewers and Other Buried Applications
- A798 - A798/A798M-97a - Practice for Installing Factory-Made Corrugated Steel Pipe for Sewers and Other Applications
- A807 - A807/A807M-97 - Practice for Installing Corrugated Steel Structural Plate Pipe for Sewers and Other Applications
- A810 - A810-94 - Specification for Zinc-Coated (Galvanized) Steel Pipe Winding Mesh
- A813 - A813/A813M-95e2 - Specification for Single- or Double-Welded Austenitic Stainless Steel Pipe
- A814 - A814/A814M-96 (1998) - Specification for Cold-Worked Welded Austenitic Stainless Steel Pipe
- A849 - A849-99 - Specification for Post-Applied Coatings, Pavings, and Linings for Corrugated Steel Sewer and Drainage Pipe
- A861 - A861-94e1 - Specification for High-Silicon Iron Pipe and Fittings
- A862 - A862/A862M-98 - Practice for Application of Asphalt Coatings to Corrugated Steel Sewer and Drainage Pipe
- A865 - A865-97 - Specification for Threaded Couplings, Steel, Black or Zinc-Coated (Galvanized) Welded or Seamless, for Use in Steel Pipe Joints
- A872 - A872-91 (1997) - Specification for Centrifugally Cast Ferritic/Austenitic Stainless Steel Pipe for Corrosive Environments
- A885 - A885/A885M-96 - Specification for Steel Sheet, Zinc and Aramid Fiber Composite Coated for Corrugated Steel Sewer, Culvert, and Underdrain Pipe
- A888 - A888-98e1 - Specification for Hubless Cast Iron Soil Pipe and Fittings for Sanitary and Storm Drain, Waste, and Vent Piping Applications
- A926 - A926-97 - Test Method for Comparing the Abrasion Resistance of Coating Materials for Corrugated Metal Pipe
- A928 - A928/A928M-98 - Specification for Ferritic/Austenitic (Duplex) Stainless Steel Pipe Electric Fusion Welded with Addition of Filler Metal
- A929 - A929/A929M-97 - Specification for Steel Sheet, Metallic-Coated by the Hot-Dip Process for Corrugated Steel Pipe
- A930 - A930-99 - Practice for Life-Cycle Cost Analysis of Corrugated Metal Pipe Used for Culverts, Storm Sewers, and Other Buried Conduits
- A943 - A943/A943M-95e1 - Specification for Spray-Formed Seamless Austenitic Stainless Steel Pipes
- A949 - A949/A949M-95e1 - Specification for Spray-Formed Seamless Ferritic/Austenitic Stainless Steel Pipe
- A954 - A954-96 - Specification for Austenitic Chromium-Nickel-Silicon Alloy Steel Seamless and Welded Pipe
- A972 - A972/A972M-99 - Specification for Fusion Bonded Epoxy-Coated Pipe Piles
- A978 - A978/A978M-97 - Specification for Composite Ribbed Steel Pipe, Precoated and Polyethylene Lined for Gravity Flow Sanitary Sewers, Storm Sewers, and Other Special Applications
- A984 - A984/A984M-00 - Specification for Steel Line Pipe, Black, Plain-End, Electric-Resistance-Welded
- A998 - A998/A998M-98 - Practice for Structural Design of Reinforcements for Fittings in Factory-Made Corrugated Steel Pipe for Sewers and Other Applications
- A999 - A999/A999M-98 - Specification for General Requirements for Alloy and Stainless Steel Pipe
- A1005 - A1005/A1005M-00 - Specification for Steel Line Pipe, Black, Plain End, Longitudinal and Helical Seam, Double Submerged-Arc Welded
- A1006 - A1006/A1006M-00 - Specification for Steel Line Pipe, Black, Plain End, Laser Beam Welded
Steel Tubes
Superheater, Boiler and Miscellaneous Tubes:
- A178 - A178/A178M-95 - Specification for Electric-Resistance-Welded Carbon Steel and Carbon-Manganese Steel Boiler and Superheater Tubes
- A179 - A179/A179M-90a (1996) e1 - Specification for Seamless Cold-Drawn Low-Carbon Steel Heat-Exchanger and Condenser Tubes
- A192 - A192/A192M-91 (1996) e1 - Specification for Seamless Carbon Steel Boiler Tubes for High-Pressure Service
- A209 - A209/A209M-98 - Specification for Seamless Carbon-Molybdenum Alloy-Steel Boiler and Superheater Tubes
- A210 - A210/A210M-96 - Specification for Seamless Medium-Carbon Steel Boiler and Superheater Tubes
- A213 - A213/A213M-99a - Specification for Seamless Ferritic and Austenitic Alloy-Steel Boiler, Superheater, and Heat-Exchanger Tubes
- A249 - A249/A249M-98e1 - Specification for Welded Austenitic Steel Boiler, Superheater, Heat-Exchanger, and Condenser Tubes
- A250 - A250/A250M-95 - Specification for Electric-Resistance-Welded Ferritic Alloy-Steel Boiler and Superheater Tubes
- A254 - A254-97 - Specification for Copper-Brazed Steel Tubing
- A268 - A268/A268M-96 - Specification for Seamless and Welded Ferritic and Martensitic Stainless Steel Tubing for General Service
- A269 - A269-98 - Specification for Seamless and Welded Austenitic Stainless Steel Tubing for General Service
- A270 - A270-98ae1 - Specification for Seamless and Welded Austenitic Stainless Steel Sanitary Tubing
- A334 - A334/A334M-99 - Specification for Seamless and Welded Carbon and Alloy-Steel Tubes for Low-Temperature Service
- A423 - A423/A423M-95 - Specification for Seamless and Electric-Welded Low-Alloy Steel Tubes
- A450 - A450/A450M-96a - Specification for General Requirements for Carbon, Ferritic Alloy, and Austenitic Alloy Steel Tubes
- A608 - A608-91a (1998) - Specification for Centrifugally Cast Iron-Chromium-Nickel High-Alloy Tubing for Pressure Application at High Temperatures
- A618 - A618-99 - Specification for Hot-Formed Welded and Seamless High-Strength Low-Alloy Structural Tubing
- A632 - A632-98 - Specification for Seamless and Welded Austenitic Stainless Steel Tubing (Small-Diameter) for General Service
- A688 - A688/A688M-98 - Specification for Welded Austenitic Stainless Steel Feedwater Heater Tubes
- A771 - A771/A771M-95 - Specification for Seamless Austenitic and Martensitic Stainless Steel Tubing for Liquid Metal-Cooled Reactor Core Components
- A778 - A778-98 - Specification for Welded, Unanneled Austenitic Stainless Steel Tubular Products
- A789 - A789/A789M-00 - Specification for Seamless and Welded Ferritic/Austenitic Stainless Steel Tubing for General Service
- A803 - A803/A803M-98 - Specification for Welded Ferritic Stainless Steel Feedwater Heater Tubes
- A822 - A822-90 (1995) e1 - Specification for Seamless Cold-Drawn Carbon Steel Tubing for Hydraulic System Service
- A826 - A826/A826M-95 - Specification for Seamless Austenitic and Martensitic Stainless Steel Duct Tubes for Liquid Metal-Cooled Reactor Core Components
- A847 - A847-99a - Specification for Cold-Formed Welded and Seamless High Strength, Low Alloy Structural Tubing with Improved Atmospheric Corrosion Resistance
- A908 - A908-91 (1998) - Specification for Stainless Steel Needle Tubing
- A953 - A953-96 - Specification for Austenitic Chromium-Nickel-Silicon Alloy Steel Seamless and Welded Tubing
- A214 - A214/A214M-96 - Specification for Electric-Resistance-Welded Carbon Steel Heat-Exchanger and Condenser Tubes
- A498 - A498-98 - Specification for Seamless and Welded Carbon, Ferritic, and Austenitic Alloy Steel Heat-Exchanger Tubes with Integral Fins
- A851 - A851-96 - Specification for High-Frequency Induction Welded, Unannealed, Austenitic Steel Condenser Tubes
Structural Tubing
- A500 - A500-99 - Specification for Cold-Formed Welded and Seamless Carbon Steel Structural Tubing in Rounds and Shapes
- A501 - A501-99 - Specification for Hot-Formed Welded and Seamless Carbon Steel Structural Tubing
Mechanical Tubing
- A511 - A511-96 - Specification for Seamless Stainless Steel Mechanical Tubing
- A512 - A512-96 - Specification for Cold-Drawn Buttweld Carbon Steel Mechanical Tubing
- A513 - A513-98 - Specification for Electric-Resistance-Welded Carbon and Alloy Steel Mechanical Tubing
- A519 - A519-96 - Specification for Seamless Carbon and Alloy Steel Mechanical Tubing
- A554 - A554-98e1 - Specification for Welded Stainless Steel Mechanical Tubing
Welded Fittings
- A234 - A234/A234M-99 - Specification for Piping Fittings of Wrought Carbon Steel and Alloy Steel for Moderate and High Temperature Service
- A403 - A403/A403M-99a - Specification for Wrought Austenitic Stainless Steel Piping Fittings
- A420 - A420/A420M-99 - Specification for Piping Fittings of Wrought Carbon Steel and Alloy Steel for Low-Temperature Service
- A758 - A758/A758M-98 - Specification for Wrought-Carbon Steel Butt-Welding Piping Fittings with Improved Notch Toughness
- A774 - A774/A774M-98 - Specification for As-Welded Wrought Austenitic Stainless Steel Fittings for General Corrosive Service at Low and Moderate Temperatures
• Piping Codes and Standards
Alloy Steels
Alloy steels have properties due to elements other than carbon.
ASTM A270 Sanitary Stainless Steel Tubing - Dimensions
Dimensions of ASTM A270 sanitary steel tubes.
ASTM A312 Stainless Steel Pipes - Bursting and Collapsing Pressures
Theoretic bursting and collapsing pressures for stainless steel pipes ASTM A312.
ASTM International
ASTM International - American Society for Testing and Materials - is a scientific and technical organization that develops and publishes voluntary standards on the characteristics of material, products, systems and services.
Carbon Steel Pipes - Comparing American & European Standards
Comparing standards of carbon steel pipes from USA, Germany, UK and Sweden.
Stainless Steel Pipes - American vs. European Standards
American - US - vs. European - German, British (UK) and Swedish - stainless steel pipe standards.
Steel Pipes - Bundling Schedules Length and Weight
Bundling schedules for standard weight and extra strong steel pipes.
Threaded & Socket Welded Steel Fittings - Pressure Classes vs. Schedules
Pressure classes, schedules and weights of pipes for threaded & socket welded fittings.
