Alloy Steels
An Alloy Steel is a steel with properties due to elements other than carbon like nickel, copper, chromium, and/or aluminum. These additional elements are used to influence the metal’s strength, ductility, corrosion resistance, and machinability.
The content of alloying elements exceeds one or more of the limits:
- manganese > 1.65%
- silicon > 0.60%
- copper > 0.60%
In addition a definite range or a minimum quantity of
- aluminum
- boron
- chromium
- cobalt
- columbium
- molybdenum
- nickel
- titanium
- tungsten
- vanadium
- zirconium
may be required.
ASME/ANSI B36.10/19 - Carbon, Alloy and Stainless Steel Pipe - Dimensions
ASTM Cross Reference Material Specifications
Cross reference for fittings, flanges, unions and cast and foged valves.
ASTM International - Standards for Steel Pipes, Tubes and Fittings
The ASTM standards covers various types of steel pipes, tubes and fittings for high-temperature services, ordinary use and special applications such as fire protection use
Metals and Alloys - Densities
