Stainless Steel Pipes - American vs. European Standards
The table below can be used to compare American and European stainless steel standards.
USA | UK | Germany | Sweden | |
AISI | BSI | Werkstoff Nr. | DIN 17006 | SIS |
304 |
304S15 304S16 |
1.4301 1.4303 |
X 5 CrNi 18 10 X 5 CrNi 18 12 |
23 32 |
304L | 304S11 | 1.4306 | X 2 CrNi 18 11 | 23 52 |
310 | 310S24 | 1.4845 | X 12 CrNi 25 21 | |
316 | 316S31 | 1.4401 | X 5 CrNiMo 17 12 2 | 23 47 |
316L | 316S11 | 1.4404 | X 2 CrNiMo 17 13 2 | 23 48 |
317L | 317S12 | 1.4438 | X 2 CrNiMo 18 16 4 | 23 67 |
321 | 321S31 |
1.4541 1.4878 |
X 6 CrNiTi 18 10 X 12 CrNiTi 18 9 |
23 37 |
347 | 347S31 | 1.4550 | X 6 CrNiNb 18 10 | 23 38 |
- A312/A312M-02 Standard Specification for Seamless and Welded Austenitic Stainless Steel Pipes covers seamless, straight-seam welded, and heavily cold worked welded austenitic stainless steel pipe intended for high-temperature and general corrosive service.
- BS 3605-(1-2):1991 Austenitic stainless steel pipes and tubes for pressure purposes
• Piping Codes and Standards
• Piping Systems
AISI 310 Stainless Steel - Properties
Thermal diffusivity, specific heat capacity, density and thermal conductivity of stainless steel AISI 310 vs. temperature.
ASTM A312 Stainless Steel Pipes - Bursting and Collapsing Pressures
Theoretic bursting and collapsing pressures for stainless steel pipes ASTM A312.
ASTM International - Standards for Steel Pipes, Tubes and Fittings
The ASTM standards covers various types of steel pipes, tubes and fittings for high-temperature services, ordinary use and special applications such as fire protection use
Piping Materials - Cost Ratios
Stainless Steel - Comparing International Standards
Comparing international stainless steel standards from America (US), France, Germany, Italy, Japan, Russia, Spain, Sweden, England (UK) and the European Union.
Stainless Steel Classifications
Stainless steels are commonly grouped into martensitic stainless steels, ferritic stainless steels, austenitic stainless steels, duplex (ferritic-austenitic) stainless steels, and precipitation-hardening stainless steels.
Stainless Steel Pipes - Allowable Pressure vs. Schedule and Size
Allowable pressure for standard seamless A312-TP316/316L stainless steel pipes - temperatures 100oF to 750oF.
Stainless Steel Weld Fittings - ANSI/ASME B36.19
Dimensions of stainless steel weld fittings according ANSI/ASME B36.19.
Stainless Steels - Identification Tests
Magnetic, spark, hardness and acid identification tests for austenitic, martensitic and ferritic stainless steels.
