Piping Materials - Cost Ratios
Installation cost ratios of common piping materials as
  • Alloy 20
  • Carbon steel (reference = 1)
  • CPVC
  • FEP lined steel
  • Stainless steel 316L
  • FRP - Vinyl ester
  • FRP - Epoxy
  • FRP - Polyester
  • Glass lined steel
  • Hastelloy
  • Monel
  • Nickel
  • Polypropylene lined steel
  • PTFE lined FRP
  • PTFE lined steel
  • PTFE lined 304L Stainless steel
  • PVC
  • PVDF
  • Rubber lined carbon steel
  • Saran lined steel
  • Stainless steel 304L
  • Titanium
  • Zirconium
related to pipes in carbon steel are indicated in the chart below:
  • PTFE - PolyTetraFluoroEthylene
  • FRP - fibreglass
  • PVDF - PolyVinyliDene Fluoride
  • FEP - Fluorinated Ethylene Propylene
Installed cost ratios are based on a 100 m (400 ft) DN 50 (2") pipe installation.
Design Strategies for Piping Systems
Piping systems design strategies - documentation, P&ID, flow diagrams - capacities and limits.
ANSI Steel Pipe Schedule 40 Chart: Dimensions, Weights & Specifications
ASTM B88 - Seamless Copper Water Tubes - Dimensions
ASTM D2241 - Poly(Vinyl Chloride) (PVC) Pressure-Rated Pipe (SDR Series) - Dimensions
Dimensions of PVC pipe SDR series.
ASTM D2665 - Standard Specification for Poly(Vinyl Chloride) (PVC) Plastic Drain, Waste, and Vent Pipe and Fittings - Dimensions
PVC drain, waste, and vent pipe dimensions.
Cement Lined Carbon Steel Pipes
Dimensions of cement lined carbon steel pipes.
EN 10312 - Welded Stainless Steel Tubes for the Conveyance of Aqueous Liquids Including Water for Human Consumption - Dimensions
Dimensions of welded stainless steel tubes according EN 10312.
Stainless Steel - Comparing International Standards
Comparing international stainless steel standards from America (US), France, Germany, Italy, Japan, Russia, Spain, Sweden, England (UK) and the European Union.
Stainless Steel Pipes - American vs. European Standards
American - US - vs. European - German, British (UK) and Swedish - stainless steel pipe standards.
