Steel Pipes Expansion Loops - Design and Calculation
The expansion loop is a common way to absorb temperature expansion and contraction in steel pipes. Expansion loops can be fabricated from standard pipes and elbows.
| Nominal Pipe Size (mm) | Approximate Expansion Capacity (mm) | ||||
| Width of Expansion Loop - w - (m) | |||||
| 0.5 | 1.0 | 1.5 | 2.0 | 2.5 | |
| 25 | 35 | 130 | |||
| 32 | 25 | 100 | 210 | ||
| 40 | 20 | 70 | 150 | ||
| 50 | 65 | 125 | 200 | ||
| 65 | 50 | 100 | 150 | 220 | |
| 80 | 40 | 75 | 125 | 190 | |
| 100 | 35 | 65 | 115 | 150 | |
U-Bends Expansion Compensator Calculator
Metric Units
This calculator can be used to calculate required width and height of an U-bends expansions compensator.
Imperial Units
The U-loops calculation is based on equation
w = 0.015 (dl ⋅ D)1/2 (1)
w = width of loop (m)
dl = α ⋅ dt ⋅ S = temperature expansion (mm)
α = temperature expansion coefficient (mm/moC)
dt = temperature change (oC)
S = length of expanding pipe (m)
D = diameter of pipe (mm)
The offset of the loop is 2 w. The length of the loop is 5 w.
Example - Steel Pipe Expansion
A 50 mm steel pipe with length 30 m is heated from 0 oC to 180 oC (typical for steam pipes pressurized to 10 bar).
The temperature expansion coefficient of the steel is 12x10-6 m/mK.
The expansion length can be calculated as
dl = (12x10-6 m/mK) (180 oC - 0 oC) (30 m)
= 0.0648 m
= 64.8 mm
The width of the loop can be calculated as
w = 0.015 ((64.8 mm) (50 mm))1/2
= 0.85 m
The "offset" of the loop (2w) is 1.71 m and the lenght of the loop (5w) is 4.27 m.
Z-Bends Expansion Compensator Calculator
Metric Units
This calculator can be used to calculate required offset in a Z-bends expansions compensator.
Imperial Units
L-Bends Expansion Compensator Calculator
Metric Units
Imperial Units
The L-loop calculation is based on equation
L = 0.063 (dl ⋅ D)1/2 (2)
L = length of loop (m)
• Sizing of Steam and Condensate Pipes
Dimensions of steam and condensate pipe lines. Calculate pressure losses, recommended velocities, capacities and more.
• Temperature Expansion
ASTM A270 Sanitary Stainless Steel Tubing - Dimensions
Dimensions of ASTM A270 sanitary steel tubes.
Copper Tubes - Expansion Loop Capacity
Capacity of copper tubes expansion loops.
Linear Thermal Expansion Coefficients of Materials
Linear thermal expansion coefficients of common materials, including metals, plastics, and composites.
Linear Thermal Expansion: Formula, Coefficients & Calculator
Piping Elbows - Thrust Block Forces
Thrust block forces on pipe bends anchors due to liquid velocities and internal pressures - online resulting force calculator.
Piping Materials - Temperature Heat Expansion and Cooling Contraction
Expansion and contraction when cast iron, carbon and carbon molybdenum steel, wrought iron, copper, brass and aluminum pipes are heated or cooled.
Sizing Steam Pipes (lb/h)
Steam Pipes - Sizing
Sizing of steam pipe lines - major and minor loss in steam distribution systems.
Steam Pipes - Thermal Expansion
Thermal expansion of steam pipes heated from room temperature to operation temperature (mm pr. 100 m pipe).
Thermal Expansion of Steam Pipes - (inches)
Expansion of steam pipes heated from room temperature to operation temperature.
