Steam Pipes - Thermal Expansion
Expansion of steam pipes when pressurized and heated from room temperature.
Operating
Temperature
(oC)
Expansion
(mm / 100 m Pipe)
66 63
93 96
121 136
149 166
177 203
204 246
232 279
260 323
Note! - to avoid unacceptable stress and damage of pipe lines - handle the expansion properly!
Example - Expansion of Steam Pipe
A system is designed for pressure 10 bar with operating temperature approximately 180 oC. As indicated in the table above (177 oC) the expansion is is approximately 203 mm100m pipe.
The expansion of a 35 m long pipe can be calculated as
dl = ((203 mm100m) / (100 m)) (35 m)
    = 71 mm
Sizing of Steam and Condensate Pipes
Dimensions of steam and condensate pipe lines. Calculate pressure losses, recommended velocities, capacities and more.
Calculate ring (or pipe) diameter expansion or contraction when temperature changes.
Linear Thermal Expansion Coefficients of Materials
Linear thermal expansion coefficients of common materials, including metals, plastics, and composites.
Linear Thermal Expansion: Formula, Coefficients & Calculator
Piping Materials - Temperature Heat Expansion and Cooling Contraction
Expansion and contraction when cast iron, carbon and carbon molybdenum steel, wrought iron, copper, brass and aluminum pipes are heated or cooled.
Sizing Steam Pipes (kg/h)
Steam is a compressible gas where pipe line mass flow capacity depends on steam pressure.
Sizing Steam Pipes (lb/h)
Steel Pipes Expansion Loops - Design and Calculation
Steel pipe expansion loops and their importance in managing thermal expansion, and how to design and size them effectively. Key considerations, calculations, and installation tips to prevent stress and damage in piping systems.
Thermal Expansion of Steam Pipes - (inches)
Expansion of steam pipes heated from room temperature to operation temperature.
