The circumference of a thin ring, a pipe or tube, can be expressed as
c0 = 2 π r0                                 (1)
c0 = initial circumference (m, inches)
π = 3.14...
r0 = initial radius (m, inches)
The change in circumference due to temperature change can be expressed as
dc = c1 - c
     =  2 π r0 dt α                                 (2)
dc = change in circumference (m, inches)
c1 = final circumference (m, inches)
dt = temperature change (oC, oF)
α = linear expansion coefficient (mm/moC, μin/inoF)
The final circumference can be expressed as
c1 = 2 π r1                                           (3)
r1 = final radius (m, inches)
Equation 1, 2 and 3 can be expressed as
dc = 2 π r1 - 2 π r0
    = 2 π r0 dt α
or transformed to
r1 = r0 dt α + r0
    = r0 (dt α + 1)                                    (4)
Equation 4 can be modified with diameters to
d1 = d0 (dt α + 1)                                     (5)
Example - Steel Pipe Diameter Temperature Expansion
A stainless steel pipe with nominal diameter 10 inches (outside diameter 10.750 inches) is heated from 68oF to 98oF. The expansion coefficient for stainless steel S30100 is 9.4 μin/inoF.
The final outside diameter can be calculated
d1 = d0 [dt α + 1]
    = (10.750 in) [((98 oF) - (68 oF)) (0.0000094 in/inoF) + 1]
    = 10.753 inches
Circular Ring - Temperature Expansion Calculator
Calculate the final diameter of a thin circular ring after temperature expansion. The calculator can be used for metric and imperial units as long as the use of units are consistent.
Thermal expansion of pipes and tubes - stainless steel, carbon steel, copper, plastics and more.
Linear Thermal Expansion
Steam Pipes - Thermal Expansion
Thermal expansion of steam pipes heated from room temperature to operation temperature (mm pr. 100 m pipe).
Thermal Expansion - Linear Expansion Coefficients
Linear temperature expansion coefficients for common materials like aluminum, copper, glass, iron and many more.
Thermal Expansion of Steam Pipes - (inches)
Expansion of steam pipes heated from room temperature to operation temperature.
